Sponsored by: CARiD
Workshop code???
Old May 10, 2019 | 11:55 PM
DeutscheBenz726's Avatar
2019 E 300 4matic 2013 SLK 250
Workshop code???
I delved into the assyst system and I understand all the codes except the workshop code 3609
anybody
know what it means?
Old May 11, 2019 | 11:00 AM
konigstiger's Avatar
'71 Pinto
Code generates vehicle-specific service sheet in the WIS/MSS.
Old Jan 16, 2020 | 05:17 AM
Kenneth Bratli's Avatar
MB B250e-drive
Question Have you found out what code 3609 means?
anybody
know what it means?
Have you got some answers? want to help me with the same problem?
Old Jan 20, 2020 | 07:36 PM
Lpwagon's Avatar
2014 E350 Wagon
At the mechanic/dealer, the workshop code is input into a piece of Mercedes software and it then spits out a lists of "services" needed that the car has determined based on mileage and time intervals programmed into the car--basically that list of service 2, 3, 8 etc. What they mean: Service 2 is a "B" service, service 3 is an oil change, service 8 is an engine air filter, and service 12 is spark plugs.
I just googled "'service 20' mercedes" and got this: https://www.mercedes-benz.ca/content...197-BEdAEN.pdf
Scroll down to the part where it lists out the service numbers and what each indicates. Ignore the distance/year intervals, because it's different for each model. However the service numbers and what is indicated are the same across all recent Mercedes (I believe).
