Sponsored by: CARiD
Possible Broken Headrest
Old May 23, 2019 | 02:48 PM
Avilly's Avatar
2014 Mercedes Benz E350
Hey Gang....have an issue with my driver's seat headrest. I was sitting in my car a few weeks ago, car turned off, and decided to recline the upper seat back since I was going to be waiting about 20 minutes or so. Once I had the seat in the proper position I attempted to push the headrest back (away from my head) since it was pulled all the way to the front from my normal driving position. As I pushed it back, like I've done hundreds of times, I heard a loud snap and the headrest gave way. Now I have a limp headrest, lol. It'll move up and down as usual with the electronic seat adjustment, but the head restraint part is limp. Almost like a part snapped or isn't engaging.
Has anyone had this problem or know how to remove the head restraint to diagnose the issue? I attached a quick clip so you can see the issue. Been searching all over YouTube and the web and can't find any info on this.
File Type: mov
Old May 23, 2019 | 03:14 PM
RA72825's Avatar
It appears you may have triggered the head restraint mechanism. Your car thinks it was rear ended. Just reset it.
Old May 23, 2019 | 03:17 PM
Avilly's Avatar
There is nothing to reset since the head restraint didn't pop open. The restraint is still in place, just doesn't engage. Did you see the video clip I posted?
Old Jan 25, 2022 | 01:56 PM
PMJ041272's Avatar
e220 w212 2015
Did you ever get this fixed, mine is the same
Hi
my headrest is the same, broken plastic fixings, I have ordered a new head rest cushion, but need advice how to access the screw holding the metal tube/clamp that has come away from the headrest cushion. It looks like I need to activate the safety mechanism to allow access to the screw.
Old Jan 25, 2022 | 02:19 PM
PMJ041272's Avatar
e220 w212 2015
Hi
The hexagonal screw to the top, how do you raise the mechanism to access?
Old Jan 25, 2022 | 08:19 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Snap trap...
try to disarm the tension spring before you start messing with it -
headrest Pre-Safe feature
Now I am curious to see what module internals they used to work the spring. It has a cover with a bunch of snaps, too fancy for just a solenoid actuator right?
