Help with Sub Wiring please!
After reading lots of great info on here about adding a separate amp and sub to my logic 7 system I installed a 12" JBL at the weekend with a matching JBL amp, my problem is the RCA signal just puts my amp into protection mode for some reason. It's a brand new amp and I tried it with a different signal and it worked fine, so it's not faulty.
I have tapped the small White & Brown wires from the original amp on the rear deck and the medium black for the turn on signal. The problem seems to be with the earth of the RCA signal, as soon as it touches the amp the unit goes into protection mode. The original amp/subs work fine.
Have you got any ideas? I have had to use the high level output (Green/Green Brown) to get it to work, but it doesn't sound as good as it should. Is there somewhere else I could try to tap the signal, possibly the other amp?
Many thanks all!
Cheers.
Trev
It does seem strange it doesn't work as the stock subs do work ok so surely the RCA output must be ok?
I need to figure out which wires to tap for the RCA lines from the main amp behind the side panel and try that.......... It's a big wiring plug so lots of wires!
Cheers
Trev.
Cheers
Trev
