Sponsored by: CARiD
Engine stall into gear
Old Aug 1, 2019 | 09:02 AM
BLACK MB's Avatar
W212 e250cdi 2009
Hello,
When engine is cold, my E250cdi stalls when putting the vehicle into gear. I am forced to let the engine run for at least 5-10 minutes before I am able to put the car into gear w/o stalling.Its been like couple months now like that and nobody can find what the problem is, also no error codes been shown on diagnose. I changed ATF and filfters + replaced the MAFS and still nothing.. When engine ir warm there's no problem, only when its stay for outside for a day..
Thank you
Old Aug 1, 2019 | 09:09 AM
ygmn's Avatar
2015 E400 Sedan
SO no code when it stalls?
Old Aug 1, 2019 | 09:11 AM
BLACK MB's Avatar
W212 e250cdi 2009
No codes unfortunately..
Old Aug 1, 2019 | 09:24 AM
ygmn's Avatar
2015 E400 Sedan
What is rpm when idling everything on and off?
What happens to idle when you put foot on brake?
How is it running at idle? rich or lean?
Old Aug 1, 2019 | 09:29 AM
BLACK MB's Avatar
W212 e250cdi 2009
When its on cold and i keep brakes on idle is going down and car stalls...normally its always 800 but when on brake its dying..
Old Aug 1, 2019 | 09:47 AM
ygmn's Avatar
2015 E400 Sedan
SO it stalls not when you put it in gear but when you press brake pedal with cold engine?
Check the fuel pump idle control and how the cold engine is running at idle
Not sure, but does it have glow plugs?
and if it does; are they all working properly?
MAybe not all cylinders getting warm enough for proper idle?
I would take to good diesel mechanic who knows MB engines... which sometimes mean dealer.
Old Feb 15, 2022 | 07:09 PM
StevesS212's Avatar
Mercedes W212
Hey @BLACK MB did you ever get a resolution. I have the exact same issue.
Old Jan 16, 2025 | 07:03 AM
M_Ali's Avatar
W221 S320L
Hi,
I have the same issue with my W221 S320 (OM642).
If the car is still and the engine is cold, it stalls when I put it in either drive or reverse.
Also, compared to other cars, under normal operation, when the car is in drive or reverse, and is not moving, the engine seems to be taking the load (as compared to when in N or P); it is like a clutch half-engaged in a manual shift car.
