Sponsored by: CARiD
Are these rims will fit e350?
Old Sep 22, 2019 | 09:18 AM
Sergey Levitski's Avatar
E350 w212
Hi ,
I have Mercedes e350 4matic w212 .
Are these rims will fit my car?
Size 19×8.5
Offset +35mm
Center bore 72.7
PCD 5×114.3 ?
Old Sep 22, 2019 | 09:33 PM
E350 w212
Old Sep 22, 2019 | 09:39 PM
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
72.7 Center Bore too big. You will need to use a center hub adapter to reduce the size of the center bore.
Old Sep 22, 2019 | 09:41 PM
E350 w212
Thanks , what center bore I will need to use on my car?
Can you tell me please all the rim specifics that will fit on this car? I'm looking for 19 rims.
Old Sep 23, 2019 | 10:35 AM
up_too_late's Avatar
2015 E350 4Matic Wagon, 2018 GLE350 4Matic
I found the website https://www.wheel-size.com/ to be helpful for verifying stock dimensions and comparing with other sizes of rims and tires. I don't know if all years and models are the same but I believe the CB is 66.6mm and the bolt pattern is 5 X 112. You should also verify lug length and seat shape as you may need to get new ones.
Old Sep 23, 2019 | 01:36 PM
E55 KEV's Avatar
Veteran: Air Force
Originally Posted by Sergey Levitski
Hi ,
Size 19×8.5
Offset +35mm
Center bore 72.7
PCD 5×114.3 ?
I didn't read past Center bore size but as up_too_late stated the PCD of 5x114.3 isn't compatible either. I suggest you work with a reputable wheel dealer like Tire Rack for proper fitment.
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
