Sponsored by: CARiD
Wheel fitment
Old Oct 3, 2019 | 08:11 AM
Crni01's Avatar
C300CDI 4MATIC
Wheel fitment
Hello, i need your advice regarding wheel fitment for e 350 bluetec 4matic 2014. It s my friends car and he wants to change wheels so i dont want to advise him wrong
Wheels are Keskin KT 18
Front are 19,8.5,et45 with 245,35
Rears are 19,9.5, et45 with 275,30
Is these setup ok or will it stick out?
Does anybody have pictures with similar setup?
Old Oct 3, 2019 | 08:21 AM
RA72825's Avatar
I don’t see any issue with that setup. Stock ET is 45, so you should be good with no poke front or rear even with the wider 275 in the back. I’m running 285 in the rear on a 9.5x19 wheel with a 52 ET
Old Oct 3, 2019 | 09:57 AM
GuestFromTampa's Avatar
W212 E250 BT 4M
It definitely will not stick out,
using different size tires on 4matic is a different story ))
Old Oct 3, 2019 | 10:05 AM
Crni01's Avatar
C300CDI 4MATIC
Diference in radius is 1% - 3.3 mm which is ok with Mercedes official wheel size permissible deviations
Old Oct 17, 2019 | 10:13 PM
Billyismyname's Avatar
W221/W222/W213/X290
You will not have any problems. I’ve had 9”x19 ET 40 front and 10x19 ET 38 rear and did not rub. Make sure you get proper tires for it though. If it does rub a little you may want to roll your fenders as mine made a liiiiiitttle noise when going into corners and hitting a bump at the same time. Good luck!
