How to fix top up washer fluid
My light has been on since I bought the car always go with - 30 Celsius and didn't know why that message keep popping up all the time. Was reading here on the forum some say it can be the fluid and yess it was.
If you have the same problem you may try to change your fluid.
Here you got MB art-nr if you have same issue!
010 997 1181 and 000 998 9001
Putting up video later on the install!
My remedy was to go to JY and remove the same size grommets from MB build in 1980's as those last for decades.
Same for hose and wire holders.
They need certain PH, or whatever for current flow and not all fluids provide it.
That's where 3 grains of salt make the difference.
. And the problem started. I’ve heard about the issues like that before somewhere on the forum. I run the orange fluid out which took few min of window washing. Anyways. I bought another brand and never had a problem. My fluid is blue now.
The 3 salt grains remedy is something I pick up from respectful member on Polish MB forum and it only makes sense.
Coming to technical application, I can't verify size of Polish grains v/s USA grains, so you have to do your own experiment ..
Just normal "clean" water conducts electricity and I believe all washer fluids have water in it so hard to believe this would be a fluid issue.
