Sponsored by: CARiD
Which scanner?
Old Nov 18, 2020 | 12:48 PM
  #51
kajtek1's Avatar
1922 Ford Model T / no OBD
Originally Posted by panorth1954
I'm having hard time still with a good scanner for my E250 Bluetec sedans. I want to be able to get into a good level of detail. For example, my high end servicer in Maine could not diagnose my problem down to the faulty EGR valve I had to take it to the dealer for that. I also want to be able to do a manual DPF regeneration on my own if necessary. The car in Maine is about 45 minutes from the Mercedes dealer plus we all know what they will charge for what might be a pretty simple fix.
Allow receiving PMs in your profile.
At this point Autel dongle for $49 seems to be best deal on the market, but my E250 BT runs perfect lately, so I have not yet tested what the scanner does.
Regardless, you will like the scanner for the price.
If you monitor your engine, -acting when necessary, and the best for it is ScanGauge, you will never need manual regeneration.
Old Nov 18, 2020 | 12:55 PM
  #52
cetialpha5's Avatar
If you're not in a hurry, try the Thinkcar Pro. It's also supposed to do dpf reg. Otherwise I think you'd need a more expensive one like the Foxwell in order to do it. Takes a while to ship though, but at under $50, not too bad.
https://www.aliexpress.com/item/1005001489490192.html
Old Jun 21, 2023 | 01:59 PM
  #53
Zackkcaz25's Avatar
W212 e350
I'm assuming it's best to go with the icarsoft v3, instead of the V2?
Old Jun 21, 2023 | 07:38 PM
  #54
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
Definitely. if you are going iCarSoft, make it V3.
Old Jun 22, 2023 | 06:52 PM
  #55
Luddyludwick's Avatar
'11 E350 4Matic Wagon
Honestly, just don't. It's useless and for $200 more you can have something like an Autel that does everything. $200 on my iCarSoft MB3 is the worst money I've spent in a few years.
Old Jun 27, 2023 | 12:27 PM
  #56
buddiec's Avatar
2010 e350, 2015 glk350 2010 c300, 2004 bmw 530 6speed , 1993 vw corrado, 1997f150
ICarSoft
Man don't tell me that I just purchased the mbv3.0 waiting for it to come, I already have a autel bio directional unit it reads my bmw, Ford, chevy and vw but not a Benz except generic stuff. They say the foxwell 530 is good for Benz? Maybe I should just get zentry on a external drive from ebay since no one can seem to contact pmercury. I have three MB, for my bmw I have ista D and P, also have protool, have vag/com for my vw. What do you suggest
Old Jun 29, 2023 | 09:50 AM
  #57
There's a guy on FB W212 group, Amir Miladi, who sells Xentry. Or it's relatively easy to find elsewhere. Just have to be comfortable using a PC, and have a connector.
Old Jun 29, 2023 | 10:28 AM
  #58
buddiec's Avatar
Thanks i will look for him, i am good with software on pc as i have bmw Ista and vw Vag already and pretty good at it a learning curve but doable
