Constantly Warping Rotors
So I was wondering is there another problem that is leading to this, also, is there a possibility the car is a lemon?
I last replaced the rotors myself 6-7k miles ago in August with Stoptech Cryo treated rotors with Stoptech Sport pads, hopefully combating the warping, but the car started juddering again when stopping in November, and now it is really bad. Also, the rotors and pads were properly broken into right after the replacement.
Struts were also replaced in August, though springs were reused on the struts.
Wash the car (manually or at the carwash) when cold, not after a long drive. If you hit the car wash as the last stop on the way home from your work commute or shopping, quit that immediately. Try to avoid large puddles with hot rotors, etc.
I don't see why hills should cause warping, when all the friction parts are at proper operating temperature. It's those sudden temperature differentials between hot rotors and cold water that cause warping.
Something else is up with your car. "warped" rotors is a bit misleading - the pulsation is usually from hot spots on the rotors formed by deposits from the pads when they get really hot. Do you have an IR thermometer? Check the brake calipers/rotors temps after your wife's normal drive. See if its possible one caliper is partially sticking causing excessive heat which leads to deposits forming.
Keep us posted.
My Zimmermans w/ Pagid pads have occasionally vibrated but a hard brake or two fixes it.
Keep us posted.
The mercedes rep just contacted me, apparently, the front axle (left) has snapped in two. Maybe that is why the car is acting this way?
Is it common for the front axle to snap in E350's of this generation, or is this just my car. My wife claims that she has not hit anything, and there are no potholes where I live in Southern California, so I think that its kinda weird for it to snap.
When torn CV boot can be replaced for about $100 DIY, the dealers "don't do boots" and will charge you probably close to $2000 for axle replacement.
Reading the topic, you need to send your wife to advanced driving lessons.
I had brake pads lasting 100k miles even on old cars, when rotors are lifetime items for me. Akebonos pads after 100k miles were at 70% of their thickness when I sold the car. Never had warp rotor in my life and I have about 15-20 brands of vehicles on my records.
But can understand the situation since my stepmom, even she is senior still drives with her left foot over brake pedal. When she swears to not touch the brake, one time driving behind her I could see brake light coming on every few seconds.
Which rotor(s) are warping? Front? Rear? Just one? If it's just one you have a sticking caliper.
this is from autoblog.com
How brake rotors warp
A common misconception when rotors are referred to as “warped” is that they are no longer straight when rotating (similar to how a bicycle wheel gets warped). For cars, in order for that to be the case, the rotors themselves would have to be defective as the temperature required to make metal that resilient soft enough to simply bend would be tremendous.Instead, the warping really refers to the flat surface of the rotor becoming uneven. Heat is the number one cause of this, and can cause warping in more than one way:
- Glazing the brake rotor with material from the brake pad. This happens because brake pads, like tires, are made with different amounts of hardness and stickiness depending on the intended purpose. When brake pads made for normal road use get very hot from high-speed driving and braking, or from riding on the brakes for a prolonged period of time, the grippy material can get too soft and basically "paint" the brake rotors. This means that the brake pads won't grip onto metal when the brakes are applied once again, causing decreased brake performance that is less smooth than before."
Maybe install 550 brake parts (if they are different from the 350). Probably available for cheap from junk yards like LKQ or on Ebay.
My vote is for Centric premium coated rotors and ceramic pads, also sold as the brand name Stoptech. Stock/dealer parts are pretty well known to be junk, at least on the 550. Also make sure all the hub surfaces that mate with the back of the rotors are clean of corrosion and debris, perfectly flat when installing the new rotors. and torque the lug nuts to spec every time. Use proper grease on the caliper slide pins every time. This was the flaw in another thread.
yes, a correct brake bedding in procedure will usually cure the shuddering and pulsation that many people think is caused by warped rotors.
If you only "soft brake" and don't brake hard or firm, from time to time, glazing build up. If you don't use your brakes in a firm way, glazing builds up, as the pads are not capable of keeping the rotors clean. It will feel as if the brake pedal is pumping.
The recespie to clean glazed rotors is to do some hard braking from 60 to 0 , some 5 times in a row, and start using the brakes as they are intended to be used. It will then slowly disappear over some 500 miles.
Choosing brake pads with a higher iron content do have a positive influence on avoiding glazing build up, but are a bit more noisy.
The E class is a heavy car, and therefore the brakes are large, in order to be able to stop the car in all situations, but the disadvantage is that they easy glaze, if you have a "soft hat" driving style.
eh, whatever...
