Sponsored by: CARiD
Having Trouble removing Command Unit
Old Jan 19, 2020 | 04:53 PM
ml3504matic____'s Avatar
2015 ML400 4MATIC, 2016 C300 4MATIC, 2014 E350 4MATIC (Totaled), 2006 E350 (Sold)
I’ve already loosened the screws at the top and still nothing
Old Jan 19, 2020 | 05:20 PM
DFWdude's Avatar
2016 E350 Sport
I think the first 2-3 minutes of this one will show how to remove the fasteners from the bottom up...
https://www.youtube.com/watch?v=mA7_H4I7ai0&feature=youtu.be
or...
Old Jan 19, 2020 | 07:45 PM
prktkljokr's Avatar
12 C200, 12 C180, 10 Fuso Warrior crew cab, 08 RTV ute, 05 Smart Fortwo cabrio, 09 Smart Fortwo
When you loosen the screws you are not meant to take them out, you only need them up enough to disengage the locking mechanism that the screws are connected to , once loose you push down on the screws which will disengage the mechanism holding the radio in.
This also helps when refitting the radio as the screws are a little bit difficult to get back in without dropping them into the dash, so make sure you get them back into the thread of the mechanism.
