2013 E350 Transmission Failure
Morning,
My 2013 E 350 is at the dealership having a rebuilt transmission and torque converter installed. The only symptom was the car feeling like it was traveling on a rubble strip, usually at highway speeds while accelerating.
Questioning what exactly the failure was got me a simple answer that is what internal.
I was quoted 12,000 for the job but MB stepped up with some goodwill and is doing the work for 3500. Car has always been serviced at dealership and has 48k miles.
Here's hoping for a non eventful stretch of miles moving forward!
Received 1,747 Likes
1922 Ford Model T / no OBD
Would be nice to learn what cost the failure.
I have/had 2 of 7G who exceed 180k miles and the older one had only 1 service done per MB schedule. Both run perfect.
Is your car 4Matic? Good they are stepping up on the repair and not trying to stick it to you.
Well, got the car back today and all seems great in the short drive around the neighborhood. Final bill came in at over 15k! Dealership and MB really stepped up and took care of the majority of the bill.
Still didn't learn exactly what the failure was. The repair order is 3 or 4 pages.
My car is close to 95k miles and occasionally launch forward when I'm slowing down to 20mph.
I search within our forum and there was some suggestion about replacing the solenoid..
Thanks.
skidaddyoo (12-19-2022)
Also, my cars symptoms were nothing like yours, so that is good news for you! Hopefully yours is just a solenoid.
I had mine changed at 62k miles in my 2014. The cooling unit started leaking fluid into the transmission. So they had to replace the transmission, radiator and all hoses. $10k+ job, totally worth the extended warranty 🤣.
Dam that sucks. How common is this type of problem?
ATF heat exchangers inside radiators fail occasionally on all models and all brands, but some coolant in ATF is not killing the transmission unless neglected for long time.
Than dealers milking the warranties is nothing new.
How does "cooling unit" leak into the transmission?
Received 1,503 Likes
This was very common on the W211 on the 2003 models in the first year. The transmission cooler was part of the radiator so coolant also got into the transmission which ruined the transmission. Many replaced their radiators with updated parts that didn't have that problem.
i always thought the engine and transmission radiators are separate units.
Now new engines have so much attachments on them, that space under the hood is getting more and more valuable, so fluid heat exchangers allow for more flexibility.
My Ford truck has liquid cooled inetercooler
But even huge truck has the space under the hood so pack, that it is hard to put hand in it. On older truck much simpler engines would have space so people could "walk inside"
The metal in the radiator between the transmission fluid and the coolant degrades or fails and the fluids are allowed to mix. It's a common problem on a lot of cars.
I remember my 65 Mustang had the same combined radiator setup, FWIW.
In addition to more compact packaging and lower part counts, I've heard the reason this configuration is desirable is because the warmth from the coolant helps to heat the transmission fluid quicker, which is important in colder climates.
nope, the "transmission cooler" is just a copper tube with cooling fins on the outside of it running top/bottom in one of the plastic end tanks on the radiator, so the coolant can cool the oil. sucks, but almost all cars are like that. if you catch it early before damage to trans(the clutch material in the transmission is attached to the friction plates with a water-soluble glue...) and before radiator starts to swell up and leak, you can change the fluids and add an external cooler.
Didn't want to start a new thread, but a family member just got their 2012 E350 back after having the transmission rebuilt due to water getting into it from the radiator. Had the same exact symptoms as your car, driving like going over rumble strips. Ironic because the car is meticulously maintained and had given absolutely no problems until the shudder in December. I'll be keeping an eye out for it on my E550.
It sure does seem like a fluke with all these other members not having this problem.
Received 1,025 Likes
2010 E350 4Matic
Wow I thought that this was limited to the W211's. So I had my transfer case rebuilt a year ago at a local indy. The fluid was changed at that time. I picked up the car and it was quiet and shifted perfectly. A couple of months later I noticed that it didn't shift as smoothly and took it to the dealer to look at it. They recommended that I have the fluid checked for coolant contamination. I didn't do it that time thinking that was a W211 issue. Took it back to the indy had him look at the shifting. He didn't think it was a big deal. Been driving it since, shifts pretty much the same, 4 to 5th delayed shift and seems like it slips in third (all under light throttle). Its now going back to the indy because the transfer case is noisy. Now I am wondering if I have a coolant contamination problem. Going to try to get a sample of the fluid when they pull the transfer case.
Morning,
