Oil pan cracked after oil change
Anyway, I'm not a nuts and bolts guy so I have no clue. So I thought I would pose it here. I saw a few other threads that made it sound like this happens sometimes. Is this more common than he was making it seem? I'm trying to figure out why he was so perplexed about it.
I can only guess the shop "grease monkey" over torqued the drain plug by 10 times what crack the pan.
I would wait for another call from the manager once he realize that engine needs to be removed for oil pan replacement.
Don't 4M have the pan with axles going thru it?
Good luck man.
Good luck man.
Puddle at the top, the other 2 spots are tire tracks from the oil.
Not sure how much is there. Tow truck driver guessed over 1/2 qt. It kept leaking on the street and on the tow truck flatbed surface, so it didn’t leak a little and then stop.
I have one more prepaid maintenance left, after that no one but me will perform an oil change on my car. And that will likely be topside only, which I have been doing in between mid-way between annual dealer changes.
I just had upper pan gasket fail on my 2017 Ford Powerstroke.
Small part cost, but 800 lb engine had to come out. Covered under warranty so don't know the cost, but don't think Ford is happy about it.
OP has 4M what has very complicated pan with pass-thru for axle. I would hesitate leave pan replacement to the shop who broke it, but that makes quite complicated legal issue. Is the shop having insurance?
Are you asking if he filed under HIS insurance, or under mine? It’s not under mine. I suspect he is using some type of insurance that covers his business for things like this. He mentioned something to that effect on the first night.
Still would be interested to see the crack and hear the explanation.
reputable shops have "screw-up" insurance, but it is coming with costly premium, so not lot of indies carry it. If he is having one, his premium is going to go high.
Taking a wild guess, the mechanic probably did not use a new gasket on the plug as required and applied excessive torque to get it to seal.
It's an Errors and Omissions policy. I had one when I operated a sole practitioner consultancy. For IT work, the cost was trivial.
