Sponsored by: CARiD
Climate Control E300 W212 2016
Old Mar 10, 2020 | 05:50 PM
Abbod204's Avatar
E300
Post Climate Control E300 W212 2016
Hi Dears
I would inquire about the climate control of AC for my E300 2016 W212.
unfortunately some of cold tea was reached to my climate control and this caused that AC fan blow increased by it self to the maximum. While I'm trying to stop the AC but I couldn't even when I had switched the engine off. after a while the AC has been stopped.
Then, the climate control screen the blue and hot lights were freezed. it seems that some electrical short was happened.
After I had checked the car I found that the climate control malfunction.
Therefore, I had purchased another climate control but it is for avant-garde 2009-2011 with a part number A2129007404 since I couldn't found same of mine in our country which requires some time to deliver.
I noticed the AC fan blow is lower than the basic one on 2016 (A2129006527). for example in the lowest fan blow there is no air coming from vents. The AC is working fine and air temperature is cold but in higher fan blow rate. Morover the command screen recognizes the changes in AC settings except airflow which is freezes in screen on 0.5 next to fan icon.
the plug connection for both parts are same even the shape.
have any body have an experience with such part.
or it is something related to fan motor.
Appreciate your thoughts and support.
by the way I had already ordered same of my climate control 2016 and waiting for the delivery, meanwhile I'm using avangarde control as a temporary after observed this issue.
Regards
Old Mar 10, 2020 | 06:13 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
Sounds like you need a scanner who would tell you what is going on.
iCarsoft MBII has AC program for my car.
Old Mar 11, 2020 | 09:35 AM
Abbod204's Avatar
E300
great,, thanks for this inf. Really I’ll get one of it as it will saving the costs from going to any workshop for any pop up messages
