Sponsored by: CARiD
E350 BlueTec Motor/Transmission Mount Replacement
Old Mar 15, 2020 | 12:29 PM
dofdear's Avatar
2012 E350, 2014 GL350
Just purchased a new / used 2012 E350 BlueTec. Need to change the motor and transmission mounts. I have several questions and requesting information;
1) Is there a step-by-step procedure to replace these mounts
2) Are the bolts on-time use or can they be reused
3) what are the bolt torque specs
4) What tools and special tools are required
5) Are there any pictures available or links to other posts
Thanks in advance for any information provided,
Dan aka dofdear
Old Mar 15, 2020 | 12:39 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
Check youtube for some videos.
This is pretty basic job and this engine is relatively easy to do. I only recall odd wrench size like 16 mm, that none of my 3 metric wrench sets did have and need for long extensions with UV joint to get the top bolts.
This is not application where torquing is crucial, so I used my hand build-in sensor
Old Mar 15, 2020 | 08:27 PM
Ceric's Avatar
W212
I can take a screenshot of the step by step instructions from the official Mercedes software if you want.
Old Mar 15, 2020 | 08:48 PM
dofdear's Avatar
Please and thank you. Dan aka dofdear
