Sponsored by: CARiD
Airscarf issues E350/A207
Old Mar 15, 2020 | 01:12 PM
Dans69's Avatar
E350 (a207)
Hi all, I seem to have an issue with the airscarf. it was working fine both sides then I noticed that the light had gone off. it now goes off after 5/10 seconds.
I have found and replaced the fuse in the drivers side dash panel it HAD blown.
Now passenger side works fine no issues. Drivers side as soon as I press the switch it blows the same fuse again.
I have visually checked plugs and cables under the seats everything looks fine as far as I can tell.
I have swapped and tested both motors using the wiring from the passenger side and both work fine with no issues.
guessing it could be the airscarf controller ? is there 1 per seat ? where are they located ?
Any Help with this would be greatly appreciated very frustrating,
Many Thanks Dan
Old Mar 17, 2020 | 11:30 AM
konigstiger's Avatar
'71 Pinto
You have covered some but these would be things to check:
- CU
- Heating & fan in seat
- Floor wiring distributor (LHD - left, RHD - right)
- Under seat wiring
File Type: pdf
File Type: pdf
Old Mar 17, 2020 | 02:10 PM
Dans69's Avatar
E350 (a207)
- CU
- Under seat wiring
Wow I cannot thank you enough for this comprehensive information. I can see the airscarf controller you have shown its location I can see the white and Blue plugs I pressure they are for the left and right seats ? would swapping them over rule out or confirm if the controller is at fault ?
Many Thanks Dan
Old Mar 21, 2020 | 07:19 AM
Dans69's Avatar
E350 (a207)
ok so I have managed to resolve my issue. it was after all the connection under the drivers seat its just 2 wires. the core of the wires had become exposed and shorting out. I removed the plug cut the wires and use heat shrink around the wires and soldered back together issue resolved.
I would like to thank everyone for helping and offering advice on this.
Old Feb 1, 2021 | 08:16 AM
Paul7's Avatar
E200 Convertible
I also had similar problem and I solved it by replacing Airscarf control unit that was in the trunk behind the trim
I
posted information about that on my website: https://blogpavel.com/2021/01/30/airscarf-fix/
Airscarf module part number is: A1729000402
I have E200 convertible
