Sponsored by: CARiD
HVAC 'rest' function on a 2016?
Old Mar 17, 2020 | 03:47 PM
mtnman82's Avatar
'16 E350, gone: '03 c230k
My old W203 had a 'rest' function with the climate control, where after shutting the car off you could hit the A/C button and the car would circulate the warm coolant and put the fan on low for the occupants of the car. I don't have this on my 2016 nor have I seen it on any other 2016/facelift W212's. I'm wondering if this feature was only available thru a specific option package, if it was discontinued, or if there is some hidden way of activating it?
Old Mar 17, 2020 | 03:50 PM
ygmn's Avatar
2015 E400 Sedan
SO what an electric coolant pump?
Old Mar 17, 2020 | 04:19 PM
RA72825's Avatar
Rest function is relegated to the memory book. I enjoyed it back in the day as well.
Old Mar 17, 2020 | 09:22 PM
mtnman82's Avatar
I see the electric pump in front of the coolant reservoir. Such a shame...
Old Mar 17, 2020 | 10:06 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
REST become rare option on W211 and completely deleted on W212.
My only guess is that too many owners had "battery problems" due to it.
On other hand, electric cabin heaters become standard for cold climates, so owners of those can get the cabin cozy very fast once they start the engine.
For those who really want the car warm - Chinese make decent clones of Webasto. I just bought $100 unit for my Sprinter, where installation is a breeze.
A bit more work to fit it on sedan, but keeping your behind warm in snow storm -PRICELESS.
Old Mar 18, 2020 | 07:09 AM
DFWdude's Avatar
2016 E350 Sport
On my older MB (W203), "Rest" function was/is the only way to turn off the A/C in the Spring/Fall months. 99% of the time, I used Rest for that purpose, rather than to keep the cabin warm with residual heat.
In the Winter, I found that cabin heat worked as well in Rest mode as it did in AUTO mode. So, in general, I've kept it in Rest mode 7 months of the year (Oct--Apr), using AUTO mode only in the heat of the Summer... here in the hotter Dallas TX area.
The W212 has a proper "Off" button, so that works well for me.
BTW, it's funny to me that in 2001, the buzz here was focused on how to turn the system off. Now, some miss it...
Old Mar 18, 2020 | 11:27 AM
kajtek1's Avatar
MB makes AC kicking in year around. In cold days to prevent glass fogging, but also for self-test.
Old Mar 18, 2020 | 01:09 PM
DFWdude's Avatar
2016 E350 Sport
Slightly, if not somewhat silly, since the home country where these cars are designed and principally built is closer to the North Pole than the Equator (Berlin = 51.1° N. Latitude) Just sayin'
Old Mar 18, 2020 | 02:04 PM
kajtek1's Avatar
You'd be amazed how much drivers who do have AC in Germany are using it. Bare in mind that humidity plays huge role how human feel the heat.
I grew up in Poland, where 25C/77F was heat wave. Years in California and 77F become sweater weather.
Now 3 years in Las Vegas, where people wear hoodies at 90F.
Than sun is additional factor. Quite often we go with dogs on desert, when morning temperature is 50F. With clear sky, the sun makes me sweating in T-shirt. That's huge difference even to California who is famous as sunnystate.
Old Mar 18, 2020 | 08:01 PM
Yakatak's Avatar
2016 E63 S AMG Wagon
My Canadian import 2016 E63 S AMG has it.
Old Mar 21, 2020 | 01:30 AM
Arrie's Avatar
My car has the pump right in front of the coolant reservoir but I don’t have any way to turn it on. I would like it to circulate the coolant after engine is shut off just to eliminate the coolant boiling in the hot spots of the engine until it has cooled down.
The Audi Q7 I had in the past had this feature and I was told it was for the health of the engine but perhaps it was for the cabin heating at the same time?
Old Mar 21, 2020 | 09:08 AM
CdnMG's Avatar
2010 E350
New owner of a Canadian 2010 E350. Between the heated steering wheel, the 'rest' function and heated seats that stay on when the engine is off its the best winter optioned car I've had. (not to mention the rear wheel biased awd). The rest function works so well I usually turn it off after 5mins or so.
Old Mar 21, 2020 | 10:28 AM
kajtek1's Avatar
They made "hot spots cooling" program on SUVs, where those engines work harder, but MB engineers figure out 200-300 HP engines in sedan work very light, so no need for extra cooling.
Per my experience MB engines are much more efficient than Audi engines, so less heat produced to start with.
Old Mar 21, 2020 | 10:30 AM
kajtek1's Avatar
You have REST button on W212? How about a picture?
Old Mar 21, 2020 | 10:54 PM
Arrie's Avatar
Well,
I know 99.9% (or more) of world's cars don't have any hot spot cooling but as my car has the hardware for it why in the hell is it not used?
I'm seriously thinking of installing a timer that would run the pump for 5 or so minutes after every time I stop the engine. I cannot see any harm coming from this.
Old Mar 22, 2020 | 11:42 AM
kajtek1's Avatar
As I said, the hot spot cooling is not needed on sedans.
I drive Ford Powerstrokes for years and since I was using my trucks for hauling 30,000 lb rigs, the engines did have hot spots.
But Ford never installed any aux coolant pumps on them. I had to observe idling the engine for couple of minutes before shut down each time I hauled.
Old Mar 27, 2020 | 12:02 PM
CdnMG's Avatar
2010 E350
Key is out. Blower is on.
Old Apr 5, 2020 | 02:29 AM
S-Prihadi's Avatar
Dang...what a coincidence this post is.
I just discovered today that, after running on the highway at good speed for 20+ miles and almost zero traffic ( due to Covid-19 semi or soft lock down of my city ), my evaporator blower unit actually run as low speed
for +-30 minute after engine shut down. Its consuming about 4 amps, that is a whopping 48 watts. Car doors are locked, hood open.
I did not hear any electric pump noise though... but will investigate next time. There is only 1 electric pump, but it is for the turbo coolant which has its own baby reservoir.
I also did not check if the HVAC control is ON or not.... but will investigate next time. I stumbled upon this post when the blower is already off and my W212 is totally sleeping already.
NO, my W212 does not have rest function, I am in the tropics and do not need heating up the car interior.
Is the the way MB W212 face-lift dry out the evaporator core to prevent mildew/smell growth ? Perhaps.
Old Apr 5, 2020 | 09:43 AM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
I haven't heard this on mine. As a matter of fact, my A/C just yesterday at startup put out a foul odor.
Old Apr 5, 2020 | 10:00 AM
ygmn's Avatar
2015 E400 Sedan
I do hear the Headlight fans run when car turned off...
Loud outside the car.
Old Apr 5, 2020 | 10:18 AM
S-Prihadi's Avatar
If I did not open the blower water separator box which is on top of my battery approx 20 minutes after engine shut down, I would not realize the blower is spinning.
It was practically noiseless due to low speed. You must see the blower phsically spinning....I doubt you can hear it.
I will check again next time if this occurence is ALWAYS or some other condition/s of HVAC system must be met.
Old Apr 5, 2020 | 10:37 AM
S-Prihadi's Avatar
This I never heard the light fan running on mine...yet , but I read about it. I never really inspected my light for the fan presence though.
I also do not know which version of headlight get such cooling down. Logic says it must be the LED type as LED module itself is poor with temperature exceeding 65 Celcius.
What kind of headlight/s on yours with the auto cooling down ?
My headlight is this type :
Old Apr 5, 2020 | 11:17 AM
LILBENZ230's Avatar
Yes I have the OEM lighting package - like posted above - and I do hear the fans cooling the lights. I hear this noise very, very frequently.
Old Apr 5, 2020 | 11:43 AM
RA72825's Avatar
I have the full LED as pictured above and my cooling fans come on every single time I stop the car no matter what season.
Old Apr 5, 2020 | 11:58 AM
S-Prihadi's Avatar
Interesting guys, well noted..... I must investigate if mine which is NOT a USA version with the *orange ( *signal light or reflector ? ) on the side , has a fan or not.
