Sponsored by: CARiD
front turn signal not working
Old Apr 5, 2020 | 04:30 PM
palmer03827's Avatar
1976 450 SL, C32 AMG 2004, ML350 2010, 2004 E55, 2015 E350
I have a 2015 E350 and the right front turn signal that is integrated with the headlight assembly either comes on part way (some LED light up) or not on at all. The warning message comes on. My question. What is the most likely cause? How do your replace the turn signal LED light string that is in the headlight?
Old Apr 5, 2020 | 05:28 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
So you have the factory lighting package, if I understand you correctly?
If so, the only resolution is to replace the entire headlight assembly.
Old Apr 9, 2020 | 05:38 PM
Mohd Saadi's Avatar
W212 2011
first put the headlight on a furnace with 180 degree make sure you remove all 3 blots and all metallic pieces
after that disassemble the lights and replace the turn light
i had the same issue but on my w212 after that make sure that you assemble the headlight with high quality silicone without acid
this is the led signal
Old Apr 10, 2020 | 10:07 AM
I was afraid of that
Old Apr 10, 2020 | 12:55 PM
Mohd Saadi's Avatar
W212 2011
afraid of what
Old Apr 11, 2020 | 02:52 PM
that I would have to replace the whole assembly for just a turn signal problem.
Old Apr 11, 2020 | 02:53 PM
where did you pick up a new LED circuit assembly?
Old Apr 11, 2020 | 02:55 PM
LILBENZ230's Avatar
I mean, that depends on exactly how good you are working with this stuff. Sure you potentially dissect the entire assembly and maybe be able to repair this unit, but maybe not. The diodes are not serviceable.
Good news it that you should be able to pick up one used online or potentially even a new one at a discount - they are manufactured by Hella for Mercedes, so if you see a Hella branded one that is the same as OEM*
*potentially it will not say "Mercedes-Benz" inside the light.
Link: https://www.ebay.com/p/1583154267
Old Apr 11, 2020 | 03:07 PM
thanks LILIEBNZ230 for the tip. I will keep a look out for the Hella branded assembly. very disappointing a bad turn signal is going to run $800-1000.
Old Apr 11, 2020 | 04:06 PM
LILBENZ230's Avatar
Yeah, it sucks. Technically these units should last the lifetime of the car.. I don't see too many problems reported here with these. Just unlucky.
Old Apr 11, 2020 | 04:13 PM
konigstiger's Avatar
'71 Pinto
Post VIN I will pull part to shop OEM new/used and aftermarket.
Old Apr 13, 2020 | 08:39 AM
that would be great the VIN is WDDHF8JB1FB165445. Thanks a lot
Old Apr 13, 2020 | 10:57 AM
'71 Pinto
2128202839
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Apr 13, 2020 | 01:30 PM
2128202839
Thanks this is very helpful. I was hoping not to have to take the bumper off but not so lucky. I am going to take it to MB to confirm it is the headlight and not the controller module. I will update the post when I find out.
Old Apr 23, 2020 | 02:07 PM
2128202839
UPDATE: brought the car to MB they pulled error codes B223900, B285711, B285811, B286011. Which is error for each of the lights. The blinker and parking light is out. I know i have moisture and that will have to be fixed (thanks LLIBENZ230), but I am think that maybe it is just a module given all the light error codes.
Question for Konigstiger: which module would throw those error codes 2228700789 or 2189007306?
Old Apr 23, 2020 | 02:31 PM
2128202839
Old Apr 23, 2020 | 02:32 PM
'71 Pinto
Leaning towards control unit 2189007306, MB should have suggested repair solution along with providing codes. If replaced, may require initial startup using Xentry (MB diagnostics).
Old Apr 23, 2020 | 04:47 PM
MB would only give me a $900 to replace the light control module but refused to give me the part number.
Old Dec 5, 2025 | 01:09 AM
flynnthomas78's Avatar
Mercedes-Benz S550 (S-Class)
Hey, I had a similar issue with my Mercedes a while back, one of the front turn signals would flicker or not come on at all, and I kept getting the warning on the dash. On these newer cars, the turn signals aren’t just bulbs, they’re part of an LED string inside the headlight, controlled by a small module. Sometimes it’s just a loose connection, but other times the LED strip or the control module itself can fail. While looking for solutions online, I came across this LED control unit: https://xenons4u.co.uk/a2059006805-l...trol-unit.html. I’m not 100% sure it will fit a 2015 E350, so definitely check compatibility first. As for replacing the turn signal LED string itself, unfortunately, you can’t just swap a single LED like a normal bulb. You have to:
  1. Remove the headlight assembly from the car (usually by opening the hood and unbolting a few screws).
  2. Disconnect the wiring and control module carefully.
  3. Replace the LED strip or the entire module inside the headlight. Some people even end up replacing the whole headlight if the LED strip isn’t sold separately.
  4. Reconnect everything and test before fully reassembling.
It’s a bit more involved than a regular bulb change, but knowing about the control module and LED strip helps you understand why these issues happen and what parts to check.
Old Dec 5, 2025 | 08:41 AM
It turned out to be the control module.
