Transmission and Rear axle oil change interval?
Service recommendations address normal and heavy use , not pleasure /occasional use
TIA
TIA
Rear axle oil change is not even listed in the MB ser4vive booklet. I had mine changed at around 150 000. You get a different answer from each mechanic you ask for this but as MB does not list it before 100 000 miles I would not worry about it before that.
I keep my cars long-term... usually 7 years minimum. On those cars that I've kept long enough (80-100K miles) to warrant a transmission fluid replacement, each time I've done that, I've had to replace the transmission within months after. That's because the dufus that changed the tranny fluid insisted (despite my objections) on doing a transmission flush, rather than a simple drain and refill.. Or he did something else to guarantee that I return in short order needing a much more expensive repair.
I've been snake-bitten on 3 cars this way. Makes the old adage, "If it ain't broke don't fix it." hold special meaning to me.
My 19 year-old MB C320 has 124,000 miles on it. Unless the transmission fluid was serviced under its 4-year or 50K miles free maintenance plan, it rides today on the original fluid in its tranny, and works as new. I could have the fluid changed now, I guess. But then the service will cost as much as the car is worth... It will cost 3X more (minimum) if done at a Mercedes dealer..
So, when the service intervals are vague (at minimum) or not stated at all, that indicates to me the transmission fluid is best left alone, unless a mechanical problem dictates an incidental fluid change.
I change the engine oil and filter every year as recommended (seldom more than 5,000 miles between changes). Transmission fluid, not so much.
