Switching to 19s
Old 05-08-2020, 04:28 PM
jev_w212's Avatar
2014 E350
Not the same fenders but in terms of with it should be around the same. 255/35/19 and 285/30/19 stock amg sizes don't rub however as long as you get the right offsets wheels. It does look lowered most of the time, the sport package E350 comes 1" lower than the luxury models
The following 3 users liked this post by jev_w212:
darkshinobi (08-10-2020), pierrejoliat (03-04-2021), retna7 (05-08-2020)
Old 03-03-2021, 10:47 PM
retna7's Avatar
2000 E430 Sport
Interested to know if you have the 4matic.
If so, have you noticed any transmission problems with your tire setup?
The following 2 users liked this post by retna7:
Colmex (03-05-2021), Jojo074 (08-18-2021)
Old 03-15-2021, 11:48 PM
retna7's Avatar
2000 E430 Sport
FYSA:
245/35/19 on 19x8.5 et43 front wheel
Front fully tucked. No contact.
Rear fully tucked. No contact.
285/30/19 on 19x9.5 et43 rear wheel.
Airmatic suspension fully lowered / all air purged.
Old 06-15-2022, 03:05 PM
Gperales1's Avatar
2016 C300, 2011 E550 cabrio, 2016 GL550
[QUOTE=alamry;8042721]
my 2014 e350 4matic seating on 19'z blended with michelin pilot sport 4s -245 front 285 rear perfect fitment and handling[/
I have a 2015 e350 4matic and purchased a set of e63 wheels 19x9 19x9.5 and have been researching what tire size I should use since is a 4matic and the setup you have is what is recommended. Any issues since you put staggered wheels on your car? Thank in advance
Old 06-15-2022, 04:01 PM
DeTh's Avatar
W212 E350
[QUOTE=Gperales1;8580688]
Just stay within 1% for rotations per mile from front to rear and you will be fine. 245/35r19 and 285/30r19 are exactly the same.
The following 2 users liked this post by DeTh:
KEY08 (06-15-2022), pierrejoliat (06-16-2022)
Old 06-15-2022, 05:48 PM
KEY08's Avatar
Received 1,625 Likes on 1,192 Posts
2014 E550-sold 😩
^ yep, those are my specs on my OEM E63 19” wheels.
Old 07-17-2022, 04:47 PM
  #32
Speediee's Avatar
2014 E-350 4Matic Sport Sedan
Just to confirm these are 255/35 R19 all around? about to do the same setup and love your look!
Old 07-22-2022, 03:34 PM
  #33
Miloosh's Avatar
W212 e400 4-matic
Currently in the process of trying to make the right call for tire size as well for my 2015 e400. Couple things to consider, not all tire brands sizes are the same. Some run larger some run smaller. I just picked up a set of oem W222 sport wheels. 19x8.5/9.5 et 38 all around.
Ordered a set of Bridgestone Potenza RE980AS+’s in 255/35/19 F, and 285/30/19 rear. I think we all can agree that the rears aren’t a problem and will fit. If I plan to lower the car in the future, is the consensus to switch to a 245/35 series tire?
Appreciate the input!
Old 08-02-2022, 09:06 AM
  #34
Miloosh's Avatar
W212 e400 4-matic
Decided to go with 255 up front, 285 in the rear. No fitment issues.
The following 2 users liked this post by Miloosh:
Aussie_E350_Wag (08-02-2022), KEY08 (08-03-2022)
Old 03-10-2024, 09:15 PM
  #35
2Twelve's Avatar
Preface W212
I run similar setup to OP thought i'd post
19X8.5 Square
Front +35 offset Rear +38 offset
Front 225/40 Rear 255/35
I like the look of 19's but they are prone to bending. Looking for more tire but unsure if I will like the look.
Thoughts on a front 225/45 vs 245/40? The 225/45 should be ~1.0"+ in diameter same width and the 245/40 is only about half 0.5"+ the tire cushion and adds extra 0.5" width
The rear would need a 255/40 to match the 225/45 front and a 275/35 to match the 245/40??
FRONT 225/45 REAR 255/40
or
FRONT 245/40 REAR 275/35
Old 03-11-2024, 10:04 AM
  #36
El Cid's Avatar
2010 E350 Luxury Sedan, Engine 272 (V6)
Originally Posted by Yapz
Hi, i have a 2014 E350 with the stock 18s on tires 245/40 R18 18 +48 all around. I want switch 19s, the rims im looking at are 19 +35 with 255/35 R19 all around. Would this set up work? Or will they stick out past the fender?
19" tires will cause a deterioration in the ride.
Old 03-13-2024, 12:16 AM
  #37
Arrie's Avatar
19X8.5 Square
or
The Germans got it right. 18" rims look the best on this car.
If you want to enhance the tire look put 275/35-18 in the rear and keep 245/40-18 in front.
19" wheels make it look like you have old wagon wheels on. Some people like this look, I don't and I believe most people don't...oh, now I opened the can of worms...!!!
Old 03-13-2024, 03:17 AM
  #38
BenzV12's Avatar
W212 FL
18" wheels are most likely goldilocks of the wheels but design wise 19" wheels are my fave . I don't know what those 19" my fave rims wheels are called but they are multi spoke ones , not 5 spokes . They could be the ones used in E63s
Old 03-13-2024, 06:20 PM
  #39
KEY08's Avatar
2014 E550-sold 😩
These?
BenzV12 (03-13-2024)
Old 03-13-2024, 07:29 PM
  #40
hecdog's Avatar
2014 E350 Estate Wagon 4Matic
you’re right! These 19” wheels DO make my car look like a wagon! 😂
(staggared setup: 235/35/19 8.5” front, 255/30/19 9.5” rear).
Old 03-13-2024, 11:58 PM
  #41
BenzV12's Avatar
W212 FL
Originally Posted by KEY08
These?
Exactly, thanks for bringing these up
KEY08 (03-14-2024)
Old 03-14-2024, 04:58 PM
  #42
2Twelve's Avatar
Preface W212
These?
Oh I like those! Clean sharp looking ride sir. I prefer the thinner 5+ spoke wheels on these cars
Quick Reply: Switching to 19s
