Sponsored by: CARiD
coolant in oil
Old May 14, 2020 | 08:09 AM
michael michaeL's Avatar
w212 250cgi
coolant in oil
thank u for letting me join the forum..my spelling not so good...my name is michael i have a w212 250cgi 2009 150k... car runs fine...my car is loosing coolant... no sihns on the outside..engine blowby vapour steamy...on the dipstick brown creamy spots..no overheating issue..no oil consumption..no white smoke...any information would be apriciated...thanks
Old May 14, 2020 | 09:14 AM
speedlimit's Avatar
Administrator Emeritus
Hi Michael and welcome to MBWorld!
I'm moving you question to the W212 forum for help from fellow owners. Good luck!
Bob
Old May 14, 2020 | 09:50 AM
w212 250cgi
thank u bob
Old May 14, 2020 | 10:41 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
Take a dipstick out and let a drop of oil on white napkin, then post a picture here.
It is not easy to judge the oils, while you are saying your oil level is not changing? Also put napkin over oil fill hole with engine idling and see if it staying.
Generally the only way coolant can get to oil pan is bad head gasket.
Old May 14, 2020 | 11:19 AM
w212 250cgi
i think the coolant can enter the oil via coolant pump seal between the timing cover and engine block...seam to be a problem on compressor engine...not to shore about the m271.860cgi evo engine...is there any other way the coolant can enter the oil...is there a fix to this...
did coolant compression test ... loosing coolant very slow.. no external leak is it head gasket oil cooler or water pump gasket..on engine block. any ideas..thanks...
