Sponsored by: CARiD
Rusty Lugs
Old Jun 16, 2020 | 10:04 AM
bmwpowere36m3's Avatar
'11 E350, '11 E550, '98 M3, '95 E320
Rusty Lugs
New member to this forum! Not new to Mercedes... Recently acquired a '11 E350 4matic wagon, which will be the new family car. I can't get away from wagons as this will be my third (2 W124s prior) and I still have the '95 E320.
Anyway, the lugs on this car are rusty. Did some searches, seems pretty common and blamed on environmental regs (similar grumbling with chrome plating in US). Kind of disappointing, 25 yr lugs on W124 are in better shape. I ordered some Febi lugs for the W124 (set of snows) and was disappointed in the finish. It was more akin to heavy galvanized box store hardware, then quality zinc/chromate hardware. Actually these Febi lugs appear similar to what's on the E350 and when I search for OEM replacements.
I've read some replacing the lugs every few years due to rust. Looking for recommendation on quality lugs that won't rust in a few years?
What about the "flower" lugs off late model S class (FEBI or OTIS), having the stainless? cover over the head should reduce visable rust. I guess the question is whether they fit in diameter/pitch/ball radius and length. Any downside to these lugs, beside special socket to remove?
Old Jun 16, 2020 | 12:42 PM
RA72825's Avatar
I would not buy jacketed lugs. My Shelby came with them and my Jeep came with them. You need to be very careful and have the exact fit socket to remove. The jacket swells up when water gets in there and freezes. I bought Gorilla lug nuts for both and threw the jacketed lugs in the trash. On the Mercedes I just live with the ugly black lug bolts. . Mine are not rusted, however.
Old Jun 16, 2020 | 12:48 PM
Requisiteur's Avatar
E450 Coupe
Who sells Gorilla lug nuts? Sounds interesting.
Old Jun 16, 2020 | 02:08 PM
RA72825's Avatar
there are many sources that sell Gorilla products:
https://www.summitracing.com/search/...studs-washers?
Old Jun 17, 2020 | 07:56 AM
drdantheman1's Avatar
2014 e250 bluetec
This is so true " You need to be very careful and have the exact fit socket to remove. The jacket swells up when water gets in there and freezes. " It's a common issue on range rovers too as they all have chrome jacketed lugs. I can't tell you how many times I've had to replace all the lugs due to rust causing the caps to swell. Even had a rim damaged just trying to remove those things. To OP, definitely go with gorilla lug nuts.
Old Jun 17, 2020 | 09:03 AM
DFWdude's Avatar
2016 E350 Sport
I am just SOOOOO happy that the wells in which the lug bolts sit are so DEEP that you really don't have to look at the lug bolts.
Old Jun 17, 2020 | 09:15 AM
hyperion667's Avatar
2012 CLS63
Plus 1 for Gorilla
Old Jun 17, 2020 | 09:54 AM
pierrejoliat's Avatar
24 GLS580 '23 E450 4matic 12 E350 4Matic
I live in the rust belt, when I have a tire change or the lugs start looking rusty I take them off ,clean them , then paint them with wheel silver. I also spray lithium grease in the wheel holes, coating them after the lugs are torqued to spec, this keeps them from getting rusty, purely cosmetic, sometimes I spray them twice a winter.
Old Jun 18, 2020 | 01:09 PM
I'll look into the Gorilla lugs. Otis lnc also offers regular hex lugs, though I'm unsure if the coating is any better than OE.
As far as the Mercedes "flower" lugs (capped), a common complaint I see on the W221 forums is physical damage to the cap due to use of impact with regular 17 mm socket. I'm not sure I buy into water freezing and distorting the cap. I'd be more inclined to believe rust-jacking or rust build-up behind the cap... leading to a swollen cap.
Of course the downside is the special socket, possible damage with impact (even using special socket) and difficulty in removal down the road due to possible rust build-up.
Old Oct 10, 2020 | 08:00 AM
jfdturbo's Avatar
ML350, W221 S65
On my ML350 the lug bolts were getting pretty bad looking so I decided to freshen them up with a simple refinishing using Rustoleum. Here is what I did:
Old Oct 10, 2020 | 08:52 AM
chassis's Avatar
2017 GLE350 4MATIC
Replace the wheel bolts every 2-3 years if they are rusting. It's a regular maintenance item.
Old Oct 10, 2020 | 08:53 AM
2012 CLS63
I have the gorillaz and they have been holding up great ever since day one.....they're black too
Old Oct 18, 2020 | 09:50 AM
Roberttz's Avatar
2016 GLE 350
All,
Related question on lug nuts.
2016 GLE 350 4Matic - I decided to rotate tires and when I took out the lug nuts I see rust near the bolt head side threads.
I applied anti-seize I have before putting them back on.
However reading the owner manual it says don't apply grease the bolts can come off while driving.
Any recommendations? (I could take them out and clean it with rag cloth).
Old Oct 18, 2020 | 10:02 AM
Cool
Originally Posted by Roberttz
All,
Well, it may not be right, but when I take mine off, I spray with WD-40, wire brush the rust then paint the head with Mercedes wheel touch up paint, I do dry the threads before painting and reinstalling. I have never had one come loose, I also spray each lug nut on the car with lithium grease twice during the winter months, this keeps them from rusting. I suppose I could just buy new ones, but this seems to work out fine. I have done this for decades now on five different benz's
Old Oct 18, 2020 | 11:21 AM
chassis's Avatar
2017 GLE350 4MATIC
All,
Don't use anti-seize on lug bolts. It reduces friction, which reduces the torque required to achieve a clamp load. Said another way, at the M-B specified lug bolt torque, you have obtained a higher clamp load and higher tension in the bolt. Not what the manufacturer recommends. In the best case scenario, nothing happens. In the worst case scenario, the lug bolts shear from fatigue due to over tensioning. The wheel comes off. Then stuff happens. For me, I find the worst case scenario unacceptable, so I take action to avoid it. See below.
Replace lug bolts if they look questionable. They are cheap, all things considered.
If you must, clean the bolts with brake cleaner or similar, and dry them completely before installing.
Do not use anti-seize on lug bolts.
Old Oct 18, 2020 | 11:52 AM
Roberttz's Avatar
2016 GLE 350
Thanks for the feedback...I will remove the anti-seize just to be safe...
Old Oct 18, 2020 | 12:21 PM
jfdturbo's Avatar
ML350, W221 S65
I would also recommend tightening them to the recommended 110 ft-lb torque.
Old Oct 18, 2020 | 12:47 PM
Roberttz's Avatar
2016 GLE 350
Yes I already did that... but now clean and put it back to spec.
Old Oct 18, 2020 | 12:48 PM
RA72825's Avatar
I believe the recommended torque is 96 Lb-ft.
Old Oct 18, 2020 | 01:15 PM
DFWdude's Avatar
2016 E350 Sport
I try to get as close to this value as possible. I wish tire stores paid more attention to this, too.
One never knows when you will need to loosen the bolts on the side of the road (in less than ideal conditions). One can really work up a sweat with an overtightened bolt.
Old Oct 18, 2020 | 01:30 PM
ml3504matic____'s Avatar
2015 ML400 4MATIC, 2016 C300 4MATIC, 2014 E350 4MATIC (Totaled), 2006 E350 (Sold)
On my ML350 the lug bolts were getting pretty bad looking so I decided to freshen them up with a simple refinishing using Rustoleum. Here is what I did: https://youtu.be/RLzCjEvlym4
I actually did this to my ML 1-2 years ago and the paint has slightly chipped off now
Old Oct 18, 2020 | 08:31 PM
I ordered these lugs from Otis, maybe the same OE supplier to MB as they had star stamp on thread-end. Lug bolts shouldn't be a maintenance item, Wife's '09 Honda the chrome lugs still in great shape and my '95 E320 look no worse than the bolts off the '11 E350.
$70 for the set, not bad even if they need to be replaced every few years.
Old Oct 18, 2020 | 09:57 PM
RA72825's Avatar
^ those are stainless capped and I’m glad they work for you. I am not a fan of capped lugs or nuts for all kinds of reasons.
Old Oct 18, 2020 | 10:15 PM
chassis's Avatar
2017 GLE350 4MATIC
The photos look nice. I also agree that I wouldn't use capped lug bolts. I also wouldn't use the "flower" type bolt heads unless that was the only option available. Hex head non-capped. These are factory original on most M-Bs.
