Disconnecting both batteries simultaneously
what will I lose
IE radio code required / etc.....
Thanks T
W212, unlike older brothers does remember all settings. Even my garage & gate code.
For last 20 years MB doesn't install radios on American models.
They install command centers., who I believe need SD to pair with the car, but nothing to reset when power is disconnected.
My 2003 S500 did not.
Sequentially would be a more accurate term.
Depending what "module" you are installing, I would disconnect only the battery most likely to power it, not both... unless a trained auto electrician tells you to disconnect both.
The module I have installed today is a X car-style Module all went well and is working as it should small problem with the insulation displacement crimps (they are junk) so soldered connections for the power and ground
my mod list:
1, New center caps
2, Install Mercedes laser projectors
3, Install led grill star
4, Convert all interior bulbs to led
5, Door open leds
6, Change door mirrors to sequential led turn signals
7, Rewire for door open mirror sequence (door mirror) (powered from SAM module)
8, Install audio high level converter for amp in boot (install amp)
9, Install diamond amg grill & re-install led star convert led star to RF controlled
10, Install led grill logo
11, Chane reverse lights to high power led
12, Install x car-style roof module
Install moving sills custom made to order (in transit)
Thanks for the info guys
last go https://photos.google.com/share/AF1Q...hiUlBiVkdoWHh3
