[HELP] Can’t turn off Air Conditioner.
[Solved] Can’t turn off Air Conditioner.
My AC is working cool every day.
I don’t feel anything bad in a hot day.
However, I can’t turn off the compressor by turning off the AC button after started working.
Even though I turned off the AC button, cold air could continue.
I had to stop air conditioning system once by using OFF button to stop compressor then I had to restart blow again, even if I just wanna stop only AC and if I still need natural temps air circulation.
I don’t know it’s a problem or normal.
Does anyone know what’s the reason?
Thanks for helping.
S212, E250 -2010.
Thanks for helping.
S212, E250 -2010.
![](https://staticssl.ibsrv.net/autocomm/EvoM/fcotmicon.gif)
Received 1,751 Likes
2016 E350 Sport
After turning off the A/C at the button, it will take several minutes before the air blows warm. Turn it off and wait...
The following 3 users liked this post by DFWdude:
I tried check it according to your advice.
Since I activated A/C, then I turned off the A/C button.
Cold blow continued several minutes then it turned to warm actually like you mentioned.
1st try
It spent 6 minutes.
2nd try
It spent 1 minute.
3rd try
It spent 4 minutes.
Are these results correct?
Received 1,124 Likes
12 E350 4Matic 13 E350 4Matic AMG Sport
Thanks, DFWdude.
1st try
It spent 6 minutes.
2nd try
It spent 1 minute.
3rd try
It spent 4 minutes.
1st try
It spent 6 minutes.
2nd try
It spent 1 minute.
3rd try
It spent 4 minutes.
YAP (07-22-2020)
2016 E350 Sport
Thanks, DFWdude.
1st try
It spent 6 minutes.
2nd try
It spent 1 minute.
3rd try
It spent 4 minutes.
1st try
It spent 6 minutes.
2nd try
It spent 1 minute.
3rd try
It spent 4 minutes.
YAP (07-22-2020)
Received 1,007 Likes
'11 E350, '11 E550, '98 M3, '95 E320
I noticed this as well... however experience with older cars including MB is when you switched off the A/C is was nearly instant. So I suspect on this car, when you toggle the A/C the controller has logic, so its not a direct switch (more input). Maybe its related how long the compressor has been running, temps, humidity, minimum time running since its compressor cycle, etc...
YAP (07-22-2020)
YAP (07-22-2020)
Thank you guys.
I am a beginner. This is first post.
What an interesting discussion.
So, double thanks.
I guess SAM controls it but it seems buggy in my feeling.
Anyway,
When I’d like air blow (no A/C) ASAP, instantly, immediately, we have to do next 3 actions.
-Push “A/C” (light off)
-Push “OFF”
-Push Any button except for “A/C”.
It does not seem smart but I don’t wish to wait several minutes probably.
And also do you guys think that this order is not good for the system protection?
If the computer was programmed to protect compressor or something....but I don’t know.
Should I wait several minutes rather than above 3 actions?
By the way, Do you guys think that the waiting time can be changed since some reasons about refrigerator gas or oils refills ?
My low pressure is 38 psi (while idling). I think it's bit lower in medium value. Probably 45-50 psi would be better, I guess.
Although I don’t have any gear to measure high pressure valve.
So, double thanks.
Anyway,
-Push “OFF”
Thank you guys.
So, double thanks.
Anyway,
-Push “OFF”
Should I wait several minutes?
My lower pressure is 38 psi. Bit lower medium value. I don’t have any gear to measure high pressure valve.
So, double thanks.
Anyway,
-Push “OFF”
The rather long time it takes for the cooling coil to run out of cool I think is to serve cars with the ECO engine START/STOP. If the coil would instantly loose cool it would mean ECO START/STOP would never work in warm climate as A/C would be lost for any length of engine stop.
2016 E350 Sport
A/C does so many things other than simply cool a car's interior. Turn on the windshield defroster and the A/C starts automatically to dehumidify the air hitting the windshield. It's been that way for decades (long before ECO Start/Stop). There are other examples. But yes... serving ECO Start/Stop functions might be just one more reason (among dozens?)
In today's "LUXURY" cars, it's presumed that the owner will let the "Climate Control" unit run automatically, all the time. Hence, I'm not convinced that Luxury cars are engineered to run without full-time climate control. Heck, my 2001 C320 does not even offer an "OFF" button for its A/C. Instead, I select the "Rest" button and wait several minutes for ambient air.
So, on the occassion when A/C is not needed, I think today's luxury car has to complete several steps to shut down, which is against the norm. I've driven my share of econoboxes where the A/C immediately ceases when A/C is "deselected." Not so at all with upmarket, luxury models... of the same era.
pierrejoliat (07-27-2020)
Some makes sense.
I still wonder something.
-Push “OFF”
When I did this order, A/C could stop instantly.
I can hit a natural temps (no AC) air in 2 seconds every time.
It's an easier solution than the solution what Arrie mentioned on #9, I think. (Sorry, and Thank you so much, Arrie).
But I am worry about this solution due to the unknown reason of this system.
When I just turned A/C light off, then I was putting my hand on the center vent while waiting 6 minutes to notice the turning point of actually AC off. The turning point was so clear. That’s not crossfade.
I hope to know the reason and criterion about these additional time.
6 minutes was very long even though I had used AC for only few minutes before the action.
And the timing is not same every time. Sometime 1 minute, sometime 4 minutes.
I thought this is a trouble so I opened this thread.
Now I know there are some friends have similar issues but I don’t know all guys are in same condition.
I also wish to know the average time to stop AC actually since AC light off.
-Push “OFF”
Some makes sense.
-Push “OFF”
-Push “OFF”
When you turn the system OFF and then start it without A/C running then it probably skips the recovery part as the compressor was not running first and adjust the air mixing gates so it does not pull cooled air from the evaporator coil?
Just trying to guess how the system works but I'm sure there is nothing wrong in yours.
YAP (07-23-2020)
