Strange abs fault
i have an 2010 w212 350cdi 4matic
And the fault is when i drive short distances the abs light dosen't light up but when i drive about 20-30 km the abs and esp lights shows up if i restart the car the fault dissepears but it comes on again after few kilometers
I read the codes and it shows the rear left abs sensor
Fault: Component ''L6/3 (Left rear axle rpm sensor)'' has a mechanical fault. Component 'L6/3
(Left rear axle rpm sensor)' has a mechanical fault. / Fault: No DF11i sensor mounted on wheel
WSS_FL (Signal width is bigger than possible). / Fault: The air gap between component 'L6/3
(Left rear axle rpm sensor)' and the sensor rotor is too large.
This was the fault i got on carly software
Could this be just a bad speed sensor or could it be the magnetic ring
Sorry for bad bad english
The other thing I would look at is the wheel bearing. If wheel bearing wears too much it can allow the sender ring move off place and move the ring too far from the sensor like the error message says about the air gap.
Your finglish is fine...
