Sponsored by: CARiD
W212 AMG Glove box peeled off low milage *pics*
Old Aug 9, 2020 | 07:25 PM
AMGster92's Avatar
Vw passat
Hi, just recently got my W212 E63 AMG Everything runs smooth. But two days ago I just noticed that the glove box door has now seperated layers. The attached pictures will.make it easier to explain. Should I just glue the layers together or is there a more 'classy' way to do it? And by the way what could have caused it?
Old Aug 9, 2020 | 08:55 PM
RA72825's Avatar
I have never seen any Mercedes with that issue. Is the car from a hot climate, like Nevada or Arizona? Not a flood car, right?
Not sure how best to adhere that as the outside appears deformed. Maybe try to source a new door from a junk yard.
Old Aug 10, 2020 | 12:24 AM
Arrie's Avatar
It is a used car outside warranty, right? You have nothing to loose if you try to glue it back together. Good contact cement should do it or a good 5 min 2-part epoxy might be needed.
It looks like the plastic door has sprung straight so this probably is the reason for the glue to fail.
Can you bend the door back by hand to close the gap between parts? If not then gluing may not work...?
Old Aug 10, 2020 | 08:05 AM
AMGster92's Avatar
Vw passat
It has been under the sun for extended periods of time. Car was not flooded. It has been hot here recently.
Old Aug 10, 2020 | 08:08 AM
AMGster92's Avatar
Vw passat
I can bend it back but it doesnt stick there ofcourse. It is a used car out of warranty. I do suspect its the regular cleaning of the interior as i been cleaning the car every weekend inside and out too. I think the car wasg was using wet cleaning or something similar to steam cleaning
Old Aug 10, 2020 | 08:15 AM
RA72825's Avatar
I wouldn’t use any kind of heated cleaning method like steam on the interior plastic components. Carpet, yeah that’s fine.
It’s possible they went a little crazy around that area with a steam wand and broke the glue bond.
Old Aug 10, 2020 | 10:49 AM
Fliplegend's Avatar
S212 E350 Estate
Judging by some of the markings at the top of the glove box, it looks like someone may have tried to break into it. Heat could also be an explanation. As for fix, glue and a large binder clip to hold it together until the glue dries.
Old Aug 10, 2020 | 11:37 AM
RA72825's Avatar
Place a thin piece of board across the top on the outside to clamp to so you don't deform the cover, and hope for the best.
Old Aug 10, 2020 | 11:43 AM
Fliplegend's Avatar
S212 E350 Estate
Thumbs up
Good call.
