Aftermarket Driveshaft? Just Don't...
![](https://staticssl.ibsrv.net/autocomm/EvoM/fcotmicon.gif)
![Thumbs down](https://mbworld.org/forums/images/icons/icon13.gif)
So...I finally got around to changing my front driveshaft with the aftermarket one I bought a couple months ago. I noticed a slight vibration a while ago and saw the u-joint was dry and had play in it when I installed my downpipes. I tore everything down and installed the new shaft with no issues. Drove out of the shop, attempted to launch the car and it felt "spongy". I tried again, foot on brake, load to 2,200rpm and BAM!!! Twisted the brand new driveshaft IN HALF! I mean, like it was made out of paper. So disappointed in myself, I should have known better. Anyway, I have a used factory shaft coming in on Wednesday and I'll be installing it Thursday morning. I'll post pics of the carnage then.
pierrejoliat (09-01-2020)
2010 e550 p2
When i had vibrations i took the car to the shop and they found my flex discs were loose so they tightened them and the vibration went away.
Sorry about what happened. I hope it didnt damage anything.
Received 4,393 Likes
It reminded me of a friend's yacht. His 45 footer with 550HP detroit diesel went aground.
To speed up things, he went for 316 SS shaft instead of original propeller shaft which is usually special branded alloy called Aquamet 22 which needed to be imported and will take 2 months.
In under 50 hours of use, the 316 SS twisted and became useless.
Why did u change drive shaft to aftermarket one in the 1st place ?
pierrejoliat (09-10-2020)
yes, it was almost $800 for a new one from MB vs $100 for one from ebay. I knew it was a gamble. I bought it months ago when I first discovered the issue with the bad u-joint(I have a quick video of the u-joint slop I'll post here tomorrow as well) and it's been sitting in my garage. Not to many launches on it after I discovered it and realized the noise and vibration from it were getting worse, but it still held up. I could have reinstalled the old one and drove the car, but decided to just leave it down till tomorrow and fix it then. Don't want to do the job 2 more times...once more is enough. I found a used shaft for $300 with very low mileage that I will be inspecting thoroughly before installing it, and it has a 6 month warranty as well...just in case, lol.
All is well! YAY!!!
Here is the old joint/shaft:
Here is the cheap-*** POS shaft after attempting to launch the car:
Received 1,124 Likes
12 E350 4Matic 13 E350 4Matic AMG Sport
![Talking](https://mbworld.org/forums/images/icons/icon10.gif)
https://www.instagram.com/p/CE8FrRRn...d=dh29wyuenzu4
https://www.instagram.com/p/CE8GUFXH...=1aart1ib90l2y
