ABS ESP traction control
After changing the brakes when i drive the car the noise is still there
So I've changed the set ball bearing
So the noise reduced a little bit but it's still there
But this time with some lights on the dashboard (ABS, TRACTION)
so i put the car on scanner the fault is from the rpm sensor or abs sensor
I've changed tge sensor but the problem is still here
When i reput it on scanner the fault is the 2 front sensors this time 💔😭 right and left
So I've the problem of the noise and the abs sensor
What should I do
Text me on wp please +96170514782
