2016 E350 4matic Potential Purchase
I have stumbled upon a potential really good deal on a 2016 E350 4matic with less than 40K miles. I currently have a W205 C300 and have seen that they are pretty mechanically sound. I did some research here in this forum to try and gauge how reliable the facelifted W212's are, however it seems as most of the dialogue pertains to the preface lifted models. If any of you could shed some light on if there are typical problem areas on the post-facelift models (2014-2016), I would greatly appreciate any insight. For whatever reason, I am feeling a little paranoid about longer-term reliability with this model.
I just got the car back from the dealer for some warranty work:
1. Trim (Burl wood) replaced
2. Steering bolt recall
3. Rear hatch window replaced due to defective defroster
4. COMMAND upgrade to latest firmware which will allow activation of CarPlay/Android Auto.
Before I purchased my S212, I had read that 4Matic has a tendency to have fast tire wear. I've owned lots of AWD Audi over the years and so I'm used to tire wear on both axle and 15 months into my ownership of S212 I haven't noticed any serious tire wear issues.
Everyone always says 4matic has more issues which while true, I've had two of them and no issues so far. The flip side of 4matic is that you get staggered wheels on RWD so the rear tires wear out faster which also costs money. It costs money either way, either for lower gas mileage on 4matic and maybe slightly higher repair costs due to the 4matic or staggered wheels needing tires more often.
For instance, if if was in a flood it will give you problems for the entire time you own it.
For Android Auto, check out:
https://mbworld.org/forums/e-class-w...16-w212-3.html
Look at message #109 in the thread.
I got the Command update because I could duplicate a bluetooth issue on multiple Android phones, so that wasn't too difficult to get.
