Sponsored by: CARiD
Parktronic - strange problem
Old Nov 12, 2020 | 09:51 AM
Duke_Thrust's Avatar
E63 5.5 BiTurbo
Parktronic - strange problem SOLVED!
Hi guys,
My W121 E63 5.5 has developed an odd and occasional Parktronic problem:
When you first start the car and put it in gear the front sensors beep and then the two inner amber lights come on, on both sides (four in total), but not the red ones that when researching the problem seem to be more frequent.
If you switch the car off and then back on again, the problem goes away. It's only occasional and seems to be (so far) only at the first start up in the morning.
Any thoughts?
Thanks!
Old Nov 12, 2020 | 10:29 AM
S. Madman's Avatar
2012 E550 sedan 2019 E63 Wagon
Originally Posted by Duke_Thrust
Hi guys,
Any thoughts?
Thanks!
Does your car sleep outside?
Old Nov 12, 2020 | 10:30 AM
E63 5.5 BiTurbo
Originally Posted by S. Madman
Does you le car sleep outside?
It does, yes
Old Nov 12, 2020 | 10:32 AM
S. Madman's Avatar
It does, yes
Are your parking sensors wet in the morning?
Old Nov 12, 2020 | 10:46 AM
E63 5.5 BiTurbo
Yes, well they certainly were last night, it was wet and windy.
Old Nov 12, 2020 | 10:59 AM
RA72825's Avatar
My car is always garaged, but on startup the sensors will self test and beep because I am usually close to the side wall. Happens every time I start. If you keep getting a false beep with nothing around, you may have a bad sensor. If you get lights and beeps and then the system automatically shuts off, you definitely have a bad sensor. This can be diagnosed very easily at the dealer and the bad sensor replaced. Heavy rain and snow/ice wreaks havoc on the sensors and system.
Old Nov 12, 2020 | 12:06 PM
cetialpha5's Avatar
There's also the partronic button that turns it on and off. No need to shut the car off, just turn it on and off again. Those sensors do go bad once in a while. I park mine outside also and unless it's a particular bit of snow/ice on the sensor, don't get any errors. You could probably have it scanned to see if there are any errors. A scanner that does MB error codes will tell you which sensor is bad if there is one.
Old Nov 12, 2020 | 01:29 PM
DFWdude's Avatar
2016 E350 Sport
I'm with KEY08 on this one. My car is garaged overnight, and I always get sensor beeps on (cold) start-up. At first, I thought it was due to the confines of the garage. But the lack of beeps on start up in parking lots had me concluding it was self-testing.
Old Nov 13, 2020 | 05:54 AM
E63 5.5 BiTurbo
Thanks guys, I'll keep an eye on it and see what MB can tell me regarding any duff sensors should it persist.
Old Nov 13, 2020 | 12:59 PM
pierrejoliat's Avatar
24 GLS580 '23 E450 4matic 12 E350 4Matic
Talking
I have trouble with mine when I wax them by accident, try cleaning them if you waxed recently, Mine is garaged and does the same thing, the only times it turns off is after I wax and forget to clean the sensors thoroughly. Yours may be bad but this is a good place to start. I just clean them with washer fluid on a towel and the issue goes away.
Old Nov 16, 2020 | 04:22 AM
E63 5.5 BiTurbo
You might be onto something there, it had just been waxed when the problem started, will clean the sensors and see how it goes
Old Nov 16, 2020 | 08:38 AM
Yes for me in my eight years of ownership, I have had to clean them three times after they stopped working, usually I remember to clean them after each wax, which I do every six weeks. also I found if the car has sat for a few weeks, It's best if I start it without stuff in front of the car in the garage, in particular for example, it doesn't like having nothing but garage wall on the right while my backpack blower is on the floor front left. seems the self-test likes equal distances for calibration? I don't know for sure , but it seems happier if I move the backpack out from directly in front of the left corner, same thing with the snowblower in winter.
Old Jan 4, 2021 | 09:45 AM
E63 5.5 BiTurbo
Found the problem, it was not getting enough power when starting: If I paused for a second or two after turning the key to position 2 (just before engaging the starter) it'd work perfectly. Presumably it does some sort of pre-check which was being interrupted by the power draw of the starter motor.
Changed the battery and all is functioning perfectly again - I've noticed stop/start is engaging a lot more now too, which makes sense.
Old Jan 4, 2021 | 10:07 AM
Cool
Glad it worked out!
Old Jan 4, 2021 | 12:14 PM
RA72825's Avatar
Yep, battery. Time and time again on here a weak battery will cause these cars to play mind games. Start with the simple fix always; a new battery or battery disconnect/reboot.
Old Feb 5, 2021 | 12:11 AM
bmwpowere36m3's Avatar
'11 E350, '11 E550, '98 M3, '95 E320
Found an interesting setting in Xentry, it may be possible to change the audible tone setting... haven't tried it. Default is only audible when red LEDs are lit. Volume and frequency are adjustable as well.
Old Feb 5, 2021 | 04:08 AM
E63 5.5 BiTurbo
That would be great, the noise in 'red only' has always struck me as slightly irritating as it's at odds with every other car I drive.
Old Feb 5, 2021 | 08:33 AM
Talking
Yes, I heard this was available from MBHouse in Toronto, I believe it was a 50 dollar option.Makes me wonder if one looked, we might be able to turn on the euro headlight option and the sport-eco button to stay as set instead of reverting to eco at start up. Very interesting find!
Old Feb 5, 2021 | 11:00 AM
You referring to ILS? Judging that the parking beep is $50 and how easy it might be, and the ILS is $500... I suspect it is not a simple toggle in the settings. Likely requires coding, as there's more than a single module involved and without going thru MB (online), then its offline in Vediamo for example. Vediamo I'd compare to writing c code vs. changing settings in MS control panel. Obviously MB online would require login and since the feature is not allowed in the US, I cant imagine a reputable shop would due it. Even if they "could" I wouldn't be surprised if there's some mechanism in MB software blocking due to US vs. ROW in the vehicles settings.
Old Feb 5, 2021 | 12:06 PM
Cool
Could very well be, MBH is in Canada, so things might be different for them, I think they've only done one car conversion to ILS. I also would imagine MB would not look to fondly on US dealers or indy's doing this conversion on Xentry
Old Jun 8, 2023 | 11:41 AM
luffy09876's Avatar
mercedez
I apologize for bringing up this old thread. I had a similar issue with my vehicle recently; the Mercedes Parking Assist is not working properly, as I thoroughly checked the issue, I found out that I had a bad grounding issue in the system, I perfectly tight the grounding points to fix the issue. I came across an in-depth article that may be worth reading. Search for "Troubleshooting Mercedes Parking Sensor Parktronic Problems on YOUCANIC" and you will see an article that goes over common causes and possible fixes. You can read about it yourself. I hope this information can assist someone else with a similar issue.
