Sponsored by: CARiD
Remove and replace ac/heater climate control
Old Nov 21, 2020 | 03:10 PM
Tien Le's Avatar
2014 350e coupe
Hi all, I am new here. I need help with how to remove and replace climate control on 2014 350E coupe. I looked on youtube they just had how to remove Radio/Navigation/Command only. I was wonder do I have to bring it to the dealer to reprograms after replace it. Thanks.
Old Nov 21, 2020 | 03:58 PM
konigstiger's Avatar
'71 Pinto
Normally plug & play however, any problem afterward you may need to teach in actuator motors using Xentry (MB diagnostics). BTW 207 should be posting here: https://mbworld.org/forums/e-class-c...brio-a207-141/
File Type: pdf
Old Nov 21, 2020 | 04:07 PM
Tien Le's Avatar
2014 350e coupe
thank you so much.
Old Nov 21, 2020 | 04:22 PM
Tien Le's Avatar
2014 350e coupe
Hey Konigstiger, Do I need to remove the center air vent and radio command first in order to remove the climate control unit?, thanks again in advance.
