Sponsored by: CARiD
COOLANT FOR 2012 E350 4Matic
Old Dec 3, 2020 | 05:10 PM
DanW2TWLVE's Avatar
2012 Mercedes Benz E350 4Matic
What are approved coolants I can use and buy that would be at a auto parts store ?
Old Dec 4, 2020 | 02:13 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
15 years coolant life in your case will end in 2027
Old Dec 5, 2020 | 08:52 PM
ghlkal's Avatar
2012 E550 v8-Biturbo
Many of the coolant suppliers, such as Prestone, make a MB-approved mix. I found the correct stuff at WalMart.
Old Dec 5, 2020 | 09:12 PM
pierrejoliat's Avatar
24 GLS580 '23 E450 4matic 12 E350 4Matic
I use PentaFrost AF, Blue from Autozone in stock.
Old Dec 5, 2020 | 11:25 PM
bmwpowere36m3's Avatar
'11 E350, '11 E550, '98 M3, '95 E320
Top off or flush?
G-48 is the spec'd coolant, used to be G-05. Either will work if flushing. Stick with G-48 if the current coolant is original (blue/bluish-green). Zerex G-48 or G-05 concentrate from Napa and Valvoline European from WM 50/50. Or MB coolant concentrate from dealer.
Old Dec 12, 2020 | 03:02 PM
DanW2TWLVE's Avatar
Originally Posted by bmwpowere36m3
Top off or flush?
Ended up using G-05 thanks !!
