Sponsored by: CARiD
Front Brakes - Has anyone tried cryo treated rotors?
Old Dec 28, 2020 | 04:17 PM
XJLFTW's Avatar
2014 E350 Wagon, 2009 C300 4Matic (wife's car)
I'm replacing my front brakes and am considering going with cryo treated rotors (offered by Stoptech and other brands).
I'm told they're indestructible and worth the extra cost. Has anyone here tried them?
Old Dec 28, 2020 | 04:49 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
I had actually never heard of them, but I am interested. If you do try them, make sure to post up the results.
Old Dec 28, 2020 | 07:20 PM
cetialpha5's Avatar
Which car is this on? Your C300?
Also FCPEuro has a lifetime warranty on their parts so buying the rotors from them would mean you can just get another set when they wear out for free, just pay shipping.
Old Dec 29, 2020 | 07:56 AM
ygmn's Avatar
2015 E400 Sedan
Hmmmmmmmmmm Why?
Personally I think a marketing ploy to charge more.
Ask them how much stopping distance it will remove versus stock on your model car using your pads.
What happens when they get red hot from a panic stop? does all this cyro cooling mumbo jumbo go away since you not HEAT TREATED the rotors?
How many more miles do they last?
they need to provide actual numbers from testing...
Old Dec 29, 2020 | 08:46 AM
XJLFTW's Avatar
Originally Posted by ygmn
Hmmmmmmmmmm Why?
You may want to read a bit about the process itself - these questions are all easily answered and there is science behind it. They're far less of a gimmick than, say, drilled/slotted rotors.
1. Stopping distance isn't the problem they're solving.
2. The cryo process includes heat tempering, so they'll be far more stable at high temperatures than regular cast rotors, as the atomic level structure of the metal is permanently changed.
3. They last about 3 times as long, per the tests I've read.
Old Dec 29, 2020 | 09:11 AM
Duckstu's Avatar
'17 S550, '12 E550
I had a Grand Cherokee that was notoriously weak in the braking dept. With aggressive brake pads it became almost OK.
BUT,.. it would hammer through rotors. Like once a year.
So I tried the Cryo ones from the same manufacturer,.. and they lasted at least 3 years (I sold the car,.. and the brakes were still great, so I can't say how much longer, but CERTAINLY worth the extra $20 or whatever).
Unfortunately, they always seem to be offered on "high-carbon" rotors,.. and those are the ones that rust solid brown in 20 min when you wash your car. And I don't care for that. You know,.. you come home from work in the rain,.. and the next morning you back out of the garage and the brakes make that grinding sound as the rust gets scraped off?
If you can find cryo without the high-carbon,.. I'd jump on it.
Old Dec 30, 2020 | 08:18 AM
ygmn's Avatar
2015 E400 Sedan
My rotors last a longtime.. heck on truck they have 170 miles and 19 years and still rotating around as I put about 10K per year on this truck.
My E400 just rolled 40K and 4 years.... no issues yet.
I just have not had in my driving career 38yrs a car that needed rotors so much I was worried about them lasting longer.
Heck I care more about the pads lasting longer on some beasts in the past but...
If I can replace the pads after a boat load of miles and leave rotors I am happy...
2 sets of pad per rotor life to me is all I need as a minimum; I have done 3 sets once but that was on a Clunky SUV with crappy stopping distance.
I replace rotors if not true or thickness below manufacturer limit.
So again why do I need these to last longer if they last long enough now?
If you buy these are you replacing the rotor when new pads are needed??
I am all for peeps spending their money and keeping the economy rolling I am just looking for a good reason on this one as I just cannot see one.
Just trying to learn so I can make informed choice later in life
Old Dec 30, 2020 | 09:12 AM
Gazwould's Avatar
S204 C250 CDI Sport
Brembo have some special rotors out .
Old Dec 30, 2020 | 09:36 AM
pierrejoliat's Avatar
24 GLS580 '23 E450 4matic 12 E350 4Matic
Talking
Ceramics? well they are better, a tad expensive, don't know if their worthwhile for the average grocery getter. I actually put semi-metallics on my '13 sport, it stops much quicker than with the Ceramic pads and slightly less dust than the organics.
Old Dec 30, 2020 | 02:11 PM
LILBENZ230's Avatar
I mean, stopping distance is basically a function of the tires you're using more so than your brakes. At least in the real world where you don't push the brakes to the limit over and over quickly as you would, say, on a track.
Our E350 had a complete front brake job with pads/rotors at CPO process around 29,000 miles. I'm not sure if it "needed" it or not. I have never felt like the car needed "more" in terms of braking ability. Our Macan has much larger rotors and 6-piston fixed calipers.. I'm sure in a track battle, this would be better, but daily driving I can't tell a difference in abilities with the Benz running Continentals and the Porsche running Michelins. Now, the Macan setup is more attractive.. but I'm not willing to spend a ton of money on attractive brakes.
Old Dec 30, 2020 | 04:24 PM
My '13 stops quicker than my '12, it has the noticeably larger drilled rotors in front, the backs appear identical in both cars.
Old Dec 30, 2020 | 05:55 PM
Duckstu's Avatar
'17 S550, '12 E550
Originally Posted by LILBENZ230
I mean, stopping distance is basically a function of the tires ..........................
This all gets to be more of an issue with the V8 Twin Turbo cars.
My E550 has a Stage 2 flash (550 hp / 650 ft lbs),.... and I find I occasionally have to use the brakes fairly hard. Can't say for sure why.
I bought the wife a '17 S550 with the same engine,... and stock the front brakes on those supposedly need replacement as soon as 16,000 miles. Hers has 12,000 on it,.. and the front brake rotors already have a noticeable lip on the outside. And she drives SLOW. Just a function of it being a 4,850 lb car I guess.
Old Dec 30, 2020 | 06:17 PM
Duckstu's Avatar
'17 S550, '12 E550
A question I have is;
ARE ALL ROTORS FOR MERCEDES LEFT SIDE ROTORS?
I just received new Zimmerman front rotors,.. and they are directional (I.E. the vanes on the inside that are not straight,.. but rather curve in one direction,.. meaning they will flow more cooling air when installed on the left side of the car than they will on the right side.
Is this normal? I've never seen that in all my years.
Usually the curved vanes are different for each side, and re labeled as directional, with L or R stickerts on them. .And on non-directional rotors,.. the vanes go straight out from the center,.. so they flow the same air regardless of what side they are installed on.
Old Dec 30, 2020 | 06:48 PM
Wow, I have 30k on my '12 and the pads are almost 3/4 left, put brakes on my '13 first time at 64k, my wife says I never use the brake pedal, maybe she's right.
Quick story; I bought Zimmerman rotors from a Benz site, first time they were all four wrong, correct part #'s on box, second time two were right, other two different from the first shipment but still wrong! I gave up and ordered from the Benz parts place.
I agree, they sent you two lefts.
Old Dec 30, 2020 | 10:04 PM
Duckstu's Avatar
'17 S550, '12 E550
Well,.. I just checked my wife's 2017 S550, shich has drilled rotors that look exactly like the ones on my E550,.. and they do the same thing.
And with 10,500 miles on the car when I bought it this Summer,... I'm certain they're still the ones Merc put on it at the fcatory. I don't think the wheels have ever been off the car. And her rotors are like mine. The holes both aim one way, as do the vanes inside. So on the left side, the vanes are aiding the centrifugal force in pumping air through the rotor,.. and on the right the vane direction is fighting the centrifugal force.
I'm sure the centrifugal force is gonna win here,.. but the vanes going the wrong way means less air will pump through the rotor on the right than on the left.
This just seems to be a Merc thing. Never seen it done before. Normally there's warnings on brake-disk packaging to make sure this never happens. And Merc does it from the factory.
So odd.
Old Dec 31, 2020 | 12:22 AM
XJLFTW's Avatar
Per the guy I spoke to at Buy Brakes today, yes, it's normal, although the Stoptech rotors I bought are separate part numbers and are directional.
I skipped Cryo treated mainly due to timing - they're a month out and I want to get this done sooner - these seemed like the next best option: https://www.buybrakes.com/mercedes-b...-no-warp-rotor
I'm doing these pads: https://www.buybrakes.com/mercedes-b...mic-brake-pads
Old Dec 31, 2020 | 01:04 AM
LILBENZ230's Avatar
Like you've measured this? Because it's not the size of the equipment..
I don't really notice any difference between our cars despite the huge difference in size of the brake rotors or calipers. Now my W203 was ridiculously over-"braked". 189hp I4 and it had 13.6" front cross-drilled rotors (this is larger than anything on an E350) and fixed, twin piston front calipers. They used the C32 setup back then on the sport packaged C230s. I loved the way it looked, but had to replace them every 30k miles.
Old Dec 31, 2020 | 09:14 AM
Talking
As in measured actual stopping distance? No, but the rotors are noticeably bigger and on the days I drive both or one today one tomorrow, it's definitely noticeably different, the sport has more "brakes"
And yes, you would be able to tell the difference, it's a large enough margin.
Update: Wife says the brakes are more "Grabby" this is a sophisticated engineering term.
If you would like an actual measurement {of the stopping distance, LOL} I will do that when it's nice out, streets are white with salt and it's snowing, so the blue car stays garaged!
Old Dec 31, 2020 | 09:20 AM
Talking
So odd.
Yes, even in the website sellers photos they go the same way, Guess I'm wrong, I am used to directional rotors where they are left and right. Wife is gone right now so I can't check.
Yes I'm wrong, wife just got home and left rotor leads with the inside hole and right leads with the outside, mine were done at the dealer a few moths ago, so unless they used aftermarket parts which I doubt, both rotors are drilled the same, Duh..
Old Dec 31, 2020 | 09:52 AM
bmwpowere36m3's Avatar
'11 E350, '11 E550, '98 M3, '95 E320
In all the MBs we've had and worked on... I haven't, yet, come across side-specific rotors. Air is sucked in the center and accelerated outward.
Old Dec 31, 2020 | 12:59 PM
dmatre's Avatar
Had: 1987 300TD, Had: 2004 C230 Sport Sedan, Have: 2014 E350 Sport, Have: 2019 S450
Yes, I've used Cryo-Treated rotors from Porterfield when I was racing an Acura Integra back in the 90's.
The Integra was basically an overweight Honda Civic, with a twin-cam motor, and woefully undersized brakes.
Prior to going to the cryo rotors, I would warp a set of rotors in 2-3 sessions (30minutes each).
After swapping to the cryo rotors, I could get a full season out of a set of rotors (combined with PFC Red pads)
So, yes, they do perform as advertised.
However, the W212 does not have undersized brakes (especially at US speeds), so I don't believe that they're required.
I swapped out our rotors with the pads at around 85k miles, but only as a preventive measure - they weren't cracked or warped.
That being said, you're not driving a Benz because you wanted to the cheapest car you could find.
So if having a better widget installed provides more confidence/reassurance, then I say go for it (but it's not really necessary).
Old Dec 31, 2020 | 01:20 PM
fabbrisd1's Avatar
A gaggle of MB's
On Cryo - YES rotors last longer - I have not felt a braking difference in my MB's from "before-and-after" - but I don't do track work either.
On my side I have a local Cryo service that charges me $60 to do (2) rotors - since my guy is local it drop-off-pickup so no added shipping charge.
Actually - I have Cryo'd quite a few misc things since mu guy and reasonably priced especially on smaller items - a great thing has been my Cryo'd Lawn Mower blades - and a whole slew of drill-bits - also did some of my "working" chef's knives..
Old Dec 31, 2020 | 02:30 PM
Left Coast Geek's Avatar
2016 E350 4Matic wagon, 2019 Ford Expedition, 2019 Chevy Bolt EV
on previous european cars, I've had the best luck with Akebono rotors, but I've not yet changed rotors on a W212, as we've only owned it a week.
rotor wear is heavily a function of your driving style and terrain. I drive a lot in the mountains...
Old Dec 31, 2020 | 02:51 PM
Alandf's Avatar
2016 E350 Sedan
Brembo
Old Jan 1, 2021 | 02:55 PM
belarus27's Avatar
2010 e550 p2
I bought rotors from brembo they're the same way , bought 2 more different brand rotors in the past they also were the same way.
saw a cls when doing balancing on my tires at a tire shop.. not sure if his were original but they also looked the same way.. like someone mentioned maybe stoptech has it differently but ever since i got brembo i haven't had any issues even though the are all left side looks like
