Sponsored by: CARiD
Spark plug socket size for 2016 276
Old Jan 17, 2021 | 02:48 AM
Alandf's Avatar
2016 E350 Sedan
Question Spark plug socket size for 2016 276
Plugs are A 004 159 81 03
Purchased at local dealer . Friendly service advisor ( former mechanic) said that even though I am doing the work myself ,if I get the parts from dealer they will never question a warranty claim if it comes up.( like a misfire)
So.. the plugs do not have the familiar six sided hex. Searches on amazon and fcp, and other forums alternately specify 14mm thin wall ,16mm thin wall ,and 5/8 sockets.
All advice appreciated . I learned my shade tree mechanic skills on Detroit iron. So excuse my ignorance. Sill learning metric sizing
Old Jan 17, 2021 | 03:25 AM
Left Coast Geek's Avatar
2016 E350 4Matic wagon, 2019 Ford Expedition, 2019 Chevy Bolt EV
I don't know what tool is required, but have you seen any of the youtube videos on how complex removing the plugs on an m276 is? They suggest it's a 4 hour job with experience. You have to remove the intake manifolds to reach the plugs.
Ah, it's a special 12 point 14mm socket, also used by select BMW'shttps://www.fcpeuro.com/products/12-point-bmw-spark-plug-socket-14mm
Old Jan 17, 2021 | 09:13 AM
DFWdude's Avatar
2016 E350 Sport
Hmmmmm, I didn't know these were 12 point plugs. I don't understand why critical auto parts are made more vulnerable with 12 point vs traditional 6 point fasteners. It's much easier to round-off these less pronounced edges, compared with conventional hex. I guess it's to require use of torque wrench installation to prevent rounding-off.
At my age, I thought I had all the hand tools I would ever need, plus 3x duplicates. But I guess not.
Old Jan 17, 2021 | 09:43 AM
bmwpowere36m3's Avatar
'11 E350, '11 E550, '98 M3, '95 E320
Aircraft are full of 12-pt hardware... the only issue I see is when dealing with very rusty hardware, 12pt can be an issue. Regardless if its 6pt or 12pt hex, MB always spec'd torque for spark plugs. Too me, the move to 12pt on spark plugs is akin to tamper-proof fasteners... them just trying to stop the average joe from performing the work.
Old Jan 17, 2021 | 11:25 AM
chassis's Avatar
2017 GLE350 4MATIC
Please try the search function. This is covered on this site ad nauseum.
Intake manifold does not need to be removed. I did the job on a W166 in about 4 hours. Next time probably 3 hours. The passenger side plugs are easy, the driver's side plugs are a bear.
Search YouTube for Senior Leigh's videos. He is user @39039 on this site. He has a tool list. My W166 GLE ownership report thread also documents all of this.
This topic is covered ad nauseum. It's a DIY job for sure, if you know what you are doing.
Old Jan 17, 2021 | 11:36 AM
39039's Avatar
W221 S550 4MATIC
Yes, chassis is right. I also detailed the video on here, there has every detail you need.
Old Jan 17, 2021 | 03:07 PM
Alandf's Avatar
2016 E350 Sedan
Thanks and BTW I did search guess I used the wrong search terms
You didn't have to be so critical it is a users group not a school exam
Old Jan 17, 2021 | 03:15 PM
Alandf's Avatar
2016 E350 Sedan
Watched the video.
There is no actual tool list.
Old Jan 17, 2021 | 03:17 PM
I too find searching for stuff in forums to be a hit or miss proposition, the signal::noise ratio is rather low.
Old Jan 17, 2021 | 03:18 PM
Watched the video.
linked just a couple posts up is https://en.leighsr.com/spark-plugs-replace-m276
which lists all the tools he used.
Old Jan 17, 2021 | 05:56 PM
Alandf's Avatar
2016 E350 Sedan
Thanks !!
Old Jan 17, 2021 | 08:54 PM
chassis's Avatar
2017 GLE350 4MATIC
Search results with terms "M276 spark plug socket".
https://mbworld.org/forums/search.php?searchid=26790890
Old Jan 17, 2021 | 09:57 PM
Alandf's Avatar
2016 E350 Sedan
Link does not work
Old Jan 17, 2021 | 10:25 PM
chassis's Avatar
2017 GLE350 4MATIC
Link does not work
You're right, evidently the search results expire. When the Search function is used and search terms "M276 spark plug socket" are entered, posts with the required information are provided on the first page.
