Sponsored by: CARiD
Weistec Tune Post Driving
Old Jan 18, 2021 | 07:18 PM
VW2MB's Avatar
2012 E550 4matic
I've seen some things about the ECU or the TCM relearning the style of how you drive after the ECU has been disconnected for an extended period of time. Driver sportier during the learn phase or slower and smoother for faster responsive or smoother driving respectively. Well I just received my tune this past Friday, and wanted to know if there was any truth to that. If so, is there anything I should be doing during this learning period? Or has that time passed? Can I disconnect the ECU and try again? Would teaching the ECU/TCM sporty habits lower the longevity of the transmission?
Also, plan to get it dynoed this Friday. Is there anything I should pay attention to? I've heard of the mustang vs dynojet arguments. How one reads lower. But should I be looking to upgrade spark plugs or just replace them? Tires will be on once the weather warms up a tad. Just looking for some info on things I should be aware of or should look to upgrade/replace in order to compliment the tune. Not looking to add a downpipe unless it's catted. I can't deal with that sound. Lol
Old Jan 18, 2021 | 07:37 PM
ghlkal's Avatar
2012 E550 v8-Biturbo
That's a good question; I'd like to know also.
Someone with a tune will step in and let us know if the "ECU reset" still works or is needed with a tune.
Old Jan 19, 2021 | 04:04 PM
VW2MB's Avatar
2012 E550 4matic
Bump. Info needed.
Old Jan 19, 2021 | 10:54 PM
TeeEl's Avatar
2013 E550 4MATIC - P1, P2, SPORT
The only one thing that caught my eye was disconnecting the ECU. You don't need to disconnect it to force it to relearn.
https://mbworld.org/how-tos/a/merced...set-ecu-387028
Old Jan 19, 2021 | 11:19 PM
VW2MB's Avatar
2012 E550 4matic
And do you feel this needs to be done after a tune? Or does the tune negate any ecu learning curves? Also... How long is the learning period?
Old Jan 19, 2021 | 11:25 PM
TeeEl's Avatar
Honestly not sure. I reset my ECU the weekend after I got the car and then got my tune. Resetting it probably won't remove the tune mapping, but let's wait for someone who knows for sure.
Old Jan 19, 2021 | 11:50 PM
VW2MB's Avatar
2012 E550 4matic
Indeed. That's something I'm rather afraid of. Rather not risk it. But if there's some sort of optimization to be made, I'd love to know what it might be. Also, would spark plugs make much of a difference post tune? Or is that something I should've got pretune?
Old Jan 19, 2021 | 11:58 PM
Left Coast Geek's Avatar
2016 E350 4Matic wagon, 2019 Ford Expedition, 2019 Chevy Bolt EV
every car I've had that 'learns' from how you drive, about a day and 20 or 30 miles, and its relearned.
years ago I had a VW Jetta loaner for a weekend that was adaptive. apparently the shop secretary normally drove it, and it was super docile when I got it, when I brought it back 100 miles later it had decided it was in sporty mode, hah hah. mechanic/owner laughed next time I saw him, said she was pissing and moaning for a week that I'd ruined 'her' car because I was still in my rather aggressive driving phase in my late 30s. he also said not to mind her, the car NEEDED to have itself rung out and its GOOD for those motors to be revved up hard to burn the carbon out.
Old Jan 20, 2021 | 12:25 AM
VW2MB's Avatar
2012 E550 4matic
ah, well that gives me a cause for concern then. As I dont normally push my car unless necessary. Or the occasional R/T or BMW that wants to ride on me and then zoom around as if he can pass me lol So driving normally as I do, im assuming that it relearned and set itself up for a less than stellar power delivery? Id like to reset that process if possible. Even if I dont drive that way everytime, it would be nice to have that sort of power delivery/ecu adaptation when needed. How do I relearn the ECU driving habits? Ill consider driving aggressive for a day just to program it that way.
Old Jan 20, 2021 | 12:56 AM
any 'learning' car I've driven, its just the transmission shift points, and maybe the throttle response curve. you still get full power if you put your foot in it. the sportier throttle gives you a little more juice at a lighter throttle setting which makes it 'feel' more powerful, but in reality just makes it harder to drive in traffic since the throttle becomes more aggressive..
Old Jan 20, 2021 | 01:01 AM
VW2MB's Avatar
2012 E550 4matic
gotcha, makes sense. So i notice you say any learning car youve driven. Does that specifically apply to these vehicles? Or are you basically saying just, in your experience? Thanks for your input regardless. I just wish someone with some certainty would chime in a little.
Also, still curious about the spark plugs
Old Jan 20, 2021 | 01:06 AM
i don't have a v8 benz, i was speaking in general terms based on previous cars. AFAIK, my V6 E350 4matic does not 'learn' driving style, although it does have a E/S button for the transmission shifting style.
Old Jan 20, 2021 | 01:11 AM
VW2MB's Avatar
2012 E550 4matic
ah, well damn. regardless as I said tho. I appreciate your input. That at least steers me in the correct direction
Old Jan 21, 2021 | 04:55 PM
VW2MB's Avatar
2012 E550 4matic
Bump
Old Jan 22, 2021 | 07:31 AM
aty's Avatar
aty
2023 E 53 sedan
This is probably what you guys are talking about which was posted on Benzworld way back by a member who got it from a VW forum. I've used this for many years starting with my '01 SLK 320, '05 CLK 500, '12 C350 and now with my Renntech tuned '14 E550. For the 3 previous cars, I felt the need to reset the adaptive parameters every week or so depending on how aggressively I drive the car. But as one of my nephews tells us, "Just give it an Italian Tune Up" and you don't need to do this reset! lol. As for the plugs, to those who have an ECU tune, I was advised by RT to use OEM plugs but set gap to .022. Our car's transmission has torque management as I was told also by RT which reduces engine power to 1st and 2nd gear to prevent damage to it. I would like to add also that with my car now that i don't feel the need to do this reset as often as I did with the previous cars. When I drive it on the aggressive side, shift point changes (i.e. holding low gears for longer times and so on). But when driving less aggressively, it's on 6th gear even at 30-35 mph. Depending how lightly I'm pressing on the pedal.
Resetting Adaptive (or Throttle for some) Parameters:
1) Turn key to ON (before start)
2) Press throttle all the way down
3) Hold for 5 seconds.
4) Turn key Off
5) Release throttle.
6) Wait for 2 minutes.
Good Luck and have fun!
Old Jan 22, 2021 | 12:01 PM
VW2MB's Avatar
2012 E550 4matic
4) Turn key Off
Well that is some interesting information. I greatly appreciate it. So it's. It necessary by any means? It's just more of a, if u really want to or not, type deal.
Old Jan 22, 2021 | 03:12 PM
aty's Avatar
aty
2023 E 53 sedan
Yah, if you drive aggressively most of the time then I don't think you need to reset it.
Old Jan 22, 2021 | 03:14 PM
VW2MB's Avatar
2012 E550 4matic
I don't lol that's the thing. I drive smooth and luxury like mostly but occasionally I want some grunt and brute force. Didn't want my calm driving to tame the beast so to speak
Old Jan 22, 2021 | 04:04 PM
you'll still get full power if you put your foot deep enough into it. put the trans in "S" mode for brisker shifting.
Old Jan 22, 2021 | 04:06 PM
VW2MB's Avatar
2012 E550 4matic
Thanks for that
