Sponsored by: CARiD
Air bag malfunction
Old Mar 31, 2021 | 11:26 AM
Umairkhalid's Avatar
Suzuki cultus, Hond city 2011, Honda city 2003, hopefully and E250 soon
Air bag malfunction
Hi everyone! So I have a w212, whose steering buttons I have replaced. How after a full day of work, and putting it all back, the computer is through in a "front right malfunction consult workshop" and is turning on a red light which is of the air bag if I'm not wrong. Obviously I did disconnect the air bag connection, to do the work. Now is there any known way to fix this issue without going to the shop? There were no issues before doing the button replacement.
Old Mar 31, 2021 | 06:06 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
Nothing like fixing it until it's broken...
What codes are thrown?
Might be as easy as disconnecting the batteries for a bit.
Old Mar 31, 2021 | 10:09 PM
bmwpowere36m3's Avatar
'11 E350, '11 E550, '98 M3, '95 E320
If you disconnected the airbag with the battery NOT disconnected... now you have a SRS warning. It requires reset with a scan tool.
Old Mar 31, 2021 | 11:24 PM
no code is given, just this message and the srs light is thrown.
Old Mar 31, 2021 | 11:25 PM
so what if I disconnect the battery right now, take all apart again and put it back? Also I do have an OBDII 2 Bluetooth scanner, do you know some trusty scan tool for mobile?
Old Apr 1, 2021 | 12:58 PM
You can try disconnecting the battery for 10 minutes... no reason to install the old parts. In my experience you need a scan tool to reset the code.
Old Apr 1, 2021 | 01:15 PM
I'll disconnected the battery tomorrow, also I've gotten to know there are 2 batteries in a w212? One regular the other in the dash? Is that factually correct or nah, and disconnecting the main main under the hood should be enough? I am trying to find a scan tool app that actual works, so far nothing.
Old Apr 1, 2021 | 10:13 PM
Yes, there two batteries. Their location and function depends on year/model of the W212. The main (starting) battery is either in the engine compartment or trunk. The auxiliary battery is in the dash or trunk. You would disconnect the main battery if you so desire.
Old Apr 1, 2021 | 11:07 PM
Thank you so much, if iam able to find a fix I'll share it here.
Old Apr 3, 2021 | 10:01 PM
Left Coast Geek's Avatar
2016 E350 4Matic wagon, 2019 Ford Expedition, 2019 Chevy Bolt EV
I don't think the usual ELM327 Bluetooth ODBC-II dongles have the hardware required to talk to Mercedes 4-6 different CANbuses, nor do I think anyone makes any mobile app for these cars. I have one of those dongles I've used with a Toyota and a Ford truck, with the Ford the tool Forscan Lite can read ALL the codes and reset them, but there's no equivalent for Mercedes.
Old Apr 3, 2021 | 10:05 PM
the SAM (power module) disconnects the aux battery when the car is off. its only used to power the auxilliary stuff like stereo, navi, lighting when the car is being started, and its connected to the main battery+alternator when it needs charging.
so, no, you don't need to disconnect the aux battery when working on the main electrics or to attempt a power reset of any CU's
Old Apr 4, 2021 | 09:54 AM
DeltaAir423's Avatar
E250
I have had luck using my Launch X431 V Pro to talk to the CAN buses. I just haven't tried to do any SCN coding of parts. Thankfully I haven't had to replace any parts that require SCN coding yet.
Old Apr 4, 2021 | 10:18 AM
You won't be able to SCN... only Xentry "online" on for W212s.
Old Apr 4, 2021 | 10:59 AM
Hi everyone, thanks for the input, but had a guy over, he brought a professionally scanner, and cleared the code, thanks anyway.
