Android 11 Bluetooth AVRCP
W212 E350 Estate
![Smile](https://mbworld.org/forums/images/icons/icon7.gif)
My phone updated to Android 11 and my car no longer allows calls, music or any other audio connectivity.
Have tried:
- erased all bluetooth profiles on both phone+car
- upgraded COMAND at dealer to latest version
- reset system
- paired fresh
Car displays frozen mobile carrier band (does not fluctuate based on driving), and cannot reset/remove/call/stream
Anyone have ideas or tips how to solve this? Thank you!!!
Have tried:
- reset system
- paired fresh
![](https://staticssl.ibsrv.net/autocomm/EvoM/fcotmicon.gif)
Received 1,753 Likes
2016 E350 Sport
Hmmm... You probably don't want to read this, but my new Samsung S20 FE updated from Android 10 to Android 11 just after I bought it last November. All the phone-to-car functions work after the update, so with my phone, the update went well and is not glitchy.
I wonder if Android 11 has several versions dependent on country? I see you are in Switzerland. Maybe our European friends will have some useful input. Good Luck.
Received 3,449 Likes
MY'14 W212 M276 3.5NA @60kMi
scan it!
Have tried:
- reset system
- paired fresh
Have tried:
- reset system
- paired fresh
You should scan all your car modules with a obd2 scanner... Before spending too much time find the fuse for COMMAND AUDIO and give it a reset.
There are some key press combinations that will trigger a soft reset.
Have tried:
- reset system
- paired fresh
Have tried:
- reset system
- paired fresh
Have exactly the same problem, have even done a factory reset but still the same ! Had to roll back to EUMI 10 to get bluetooth connectivity with car again.
Reading through some online forums its a common problem with this update.
