Are motor (engine) mounts oil filled?
I'm tracking down an oil leak in the area of the left outer cv joint but see oil on the under-side of the motor mount. I don't know if it's the cv joint slinging oil/grease onto the mount or if the motor mount has oil in it...looks more like a thick oil than grease.
Thanks.
Thanks.
Yes, the mounts are hydraulic.
The following 2 users liked this post by KEY08:
dbldpr (04-13-2021),
pierrejoliat (04-13-2021)
Received 1,736 Likes
1922 Ford Model T / no OBD
I could never confirm that and I took few of them apart.
Even when you have fluid in MM, there is only an ounce, or 2 of it, Not enough to show as a running leak.
Received 1,007 Likes
'11 E350, '11 E550, '98 M3, '95 E320
W212 motor mounts have fluid in them, I've taken them apart: https://mbworld.org/forums/e-class-w...ml#post8249897
Not a lot, a few ounces, and the fluid is very thin. I'd would inspect the CV boot closely for tears.
The following 4 users liked this post by bmwpowere36m3:
