Sponsored by: CARiD
Navigation knob not working / broken
Old Apr 20, 2021 | 03:17 PM
ratfancy's Avatar
2011 E350
I can no longer use the rotating knob to zoom in or out on the navigation screen. I know there are voice commands for this, and I forgot! I've tried, "map out" and similar. Can't remember! I suppose would cost a pretty penny to have this fixed!
Old Apr 20, 2021 | 04:04 PM
RA72825's Avatar
Common failure. Search here for permanent DIY repair to the controller.
Old Apr 20, 2021 | 04:28 PM
Left Coast Geek's Avatar
2016 E350 4Matic wagon, 2019 Ford Expedition, 2019 Chevy Bolt EV
this is on the 2011 C350 in your profile? I believe that is a W204, not a W212, so may or may not be the same controller our W212's have (2010-2016 E class).
Old Apr 20, 2021 | 04:56 PM
cetialpha5's Avatar
I think it's the same knob though. Lots of youtube videos on how to fix it. Either you can get the replacement shaft on eBay and take it all apart to get to it or just get the replacement knob which is a lot more money,.
https://www.ebay.com/itm/Mercedes-Co...t/284260472596
Old Apr 22, 2021 | 02:53 PM
ratfancy's Avatar
2011 E350
Thank you for viewing my profile! I corrected to E350.
Old Apr 22, 2021 | 02:54 PM
ratfancy's Avatar
2011 E350
I viewed the repair video. A lot of trouble, since I haven't updated my navigation software, so it's probably the 2010 version of my local streets. I use Google maps. But once in awhile I like to position view on the screen. I know there are voice controls, can't remember what to say!
Old Apr 22, 2021 | 03:14 PM
cetialpha5's Avatar
You can get an update on eBay. I think depending on the version of NTG that you have, you can just run the update on the DVD, no special code needed. After a certain period, NTG was updated and you needed a pin code to update the navigation. I also use the comand knob to switch between different stations and different modes. You can just get a used comand knob, they seem to be under $100, There's also videos on how to take apart the trim to get at the comand knob. I swapped my faded wood and it wasn't too hard to take it apart.
Old Apr 27, 2021 | 01:15 PM
jcakers's Avatar
'85 380SL, '10 E350, '16 GL450
I have replaced the shaft in two of these units. It's pretty straight forward. You don't even have to unplug it and remove it from the car. An aluminum shaft costs $12 or $13 on Amazon.
