Sponsored by: CARiD
2010 E350 AC not blowing cold Air
Old Apr 24, 2021 | 11:56 AM
Haik2hov's Avatar
E350
Hello everyone I have a 2010 E350 the AC is not blowing cold air. I also read a post that someone had the same issue with the AC and the BT being choppy and he had software update and solved the AC issue. Has anyone have this issue. I’m wondering if I need to get a software update because my BT is also choppy sometimes.
Old Apr 24, 2021 | 12:10 PM
Dr.MercE350's Avatar
2014 Mercedes E350
You first need to find out if your ac is leaking freon before you do any updates. If it is leaking you must repair that first
Old Apr 24, 2021 | 12:51 PM
Haik2hov's Avatar
E350
I will get it checked. When I put the AC/PRO gauge on to check is the r134 is low it’s in the red zone. I don’t think the compressor is kicking on. I am also wondering if I should let some of the freon out to see if the compressor kicks on. Please let me know what you think. Thanks
Old Apr 24, 2021 | 03:31 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
BEWARE!!
Releasing your A/C refrigerant is risky because of high pressure and frost burns besides it's generally illegal.
Save yourself some time, buy a good OBD2 scanner to display the live data of your A/C system. It will report just about everything you need to troubleshoot the compressor clutch not engaging...
Old Apr 24, 2021 | 03:48 PM
Haik2hov's Avatar
E350
Can you tell me what’s a good OBD2 scanner please
Old Apr 24, 2021 | 04:29 PM
what is your budget??
Around $150 you get Autel and iCarsoft units. New models are released all the time.
Old Apr 24, 2021 | 08:47 PM
Originally Posted by Senecan
You don't have a clutch. The compressor is a variable displacement compressor, it's always on. The flow of refrigerant and piston swash plate angle is controlled by a solenoid in the compressor body. If you are over-pressure for whatever reason, the high-pressure switch will trip the ECU to cut operation to avoid damage to components. Open the high side Schrader valve and vent refrigerant to atmosphere a little at a time til you get pressure in the green on the low side. Do this while the car is running. Don't worry about the tree huggers, 134a contains no chlorine, therefore no ozone-depleting effect. It is, however, a greenhouse gas. But so is everything else. Let us know how it goes.
Do you know when they stopped using those fancy variable compressors?
My '14 just has the classic on/off clutch compressor.
Perhaps warmer locales use improved an equipment...
