Sponsored by: CARiD
Center Dash Speaker
Old Apr 27, 2021 | 09:06 AM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
Center Dash Speaker
Does pretty much any 4" dash speaker fit?
I've got access to BMW's Harmon Kardon (probably same), Bose (supposedly upgrade?), and Bowers Wilkins (best)
They're all basically the same shape, and same plugs, so basically figure I throw the best one in there and see what happens.
Not sure how logic 7 reacts to "other"
Thoughts?
Old Apr 27, 2021 | 10:44 PM
bmwpowere36m3's Avatar
'11 E350, '11 E550, '98 M3, '95 E320
As long as it fit physically and is the same impedance... I don't see what the issue would be.
Old Apr 27, 2021 | 11:41 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
Shape, impedance and frequency response range. Then you can start looking at sensitivity.
Old Apr 28, 2021 | 09:01 AM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
I can't imagine a Bose speaker working with a HK system.. everything with Bose is so different and proprietary.
I would imagine the best result would be another HK L7 speaker.
Old Apr 28, 2021 | 07:49 PM
Adi-Benz's Avatar
Structurally they all looked almost exactly the same but better build quality each step. Then again, I'm not a guru, so yeah.
Went with the most expensive one (Bowers & Wilkins)
Guess we'll see what happens. If it's a massive upgrade by shock for some reason, guess I'll have another video to make hah. If it doesn't work, it is what it is.
Old Sep 5, 2021 | 10:23 PM
Heavy AMG's Avatar
2008 ML63
Any update to the replacement speaker and whether it worked? Thanks
Old Sep 6, 2021 | 02:02 PM
Left Coast Geek's Avatar
2016 E350 4Matic wagon, 2019 Ford Expedition, 2019 Chevy Bolt EV
for playing stereo music, I don't think the center speaker is even used.
Old Sep 7, 2021 | 07:22 PM
ccww's Avatar
2015 E250 Bluetec
The center speaker is an odd duck in the W212. It has multiple purposes and is a dual voicecoil design which means that there are two separate sets of wires which connect to it. Unlike most dual voicecoil drivers which are designed to be alternately wired in series or parallel to present a different load to the amplifiers, the two voicecoils in this speaker actually have completely different purposes. One is for use with the main stereo system, at least if you have the HK Logic 7 option. There is a significant amount of content from this speaker during music playback.
The other voicecoil is connected to a different amplifier that is solely used for the MBRACE system. If you use an aftermarket replacement driver without the second voicecoil (and I don't think any have it) you will not be able to hear anything during an MBRACE emergency call, although this isn't important if you don't subscribe to the service.
More generally, I think that using aftermarket drivers as drop-in replacements is a bad idea. They have different impedance curves, T/S parameters, sensitivity, frequency response, and directionality. Unless you know exactly what you're doing and are using an aftermarket DSP crossover and EQ system to correct the response you will alter the way the system is designed to work and likely not for the better.
Old Sep 9, 2021 | 05:55 PM
The other voicecoil is connected to a different amplifier that is solely used for the MBRACE system. If you use an aftermarket replacement driver without the second voicecoil (and I don't think any have it) you will not be able to hear anything during an MBRACE emergency call, although this isn't important if you don't subscribe to the service,,,
hah, one of the two dash speakers on the W124 E's was like that back in the 1980s... the 2nd voice coil was connected to the OEM analog cell phone
