2012 E550 Cabriolet on third set of tires (62,000 miles). Last set Michelin Pilot Sport 4S had severe wear on the very inside edge of the 2 front tires down to the steel belts. Car tracks perfectly and steering wheel never gave any indication of alignment issues. Normally would take it to the dealer but the last time I took it there the service writer wrote an estimate that he thought he would retire on (over $5,300 for rough running condition). He wanted to replace injectors, harness, coil packs, spark plugs, O2 sensors....etc etc... Turns out all it needed was to update the software for the high pressure fuel system and 2 O2 sensors ($380 all in). That being said, I am now "Once bitten, twice shy" and no longer trust the integrity of the dealer I bought the car from but my local tire dealer said the complex electronics and driver assist aids and suspension components make the car "too complicated for his machine".
Should I find another indy repair shop (performance shop for example) or spin the roulette wheel and travel 45 minutes back to this criminal dealership?
CaliBenzDriver
close
- Join DateApr 2019
- LocationSilicon Valley
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I driveW212 MY'14 M276-3.5NA @75kMi
Liked:6,687 Times in 4,698 Posts
welcome to the club of twice shy who have seen the teeth inside the sharks mouth
Your solution start with changing control arms because the rubers bushings have gone soft. This afects your toe-in angle and cause your rapid tire wear on the inside.
All the suspension parts that hang your wheels have a preset useful life: control arm, ball joints, tie rods, bearings...
Watever shop that does the alignment eats that gravy - Alignment is the process of geometrically adjusting the suspension parts they've just installed.
BenzV12
close
- Join DateDec 2011
- Vehicle(s) I driveW212 FL
Liked:933 Times in 677 Posts
I would take it to a reputable tire shop . My W212 also had an uneven wears on the rear tires ,front tires were OK .It would wear off the middle portion of the threads but edges were looking OK though .
bmwpowere36m3
close
- Join DateJun 2020
- Vehicle(s) I drive'11 E350, '11 E550, '98 M3, '95 E320
Liked:1,012 Times in 679 Posts
Are we talking an alignment... no fancy computers needed. Any good alignment shop can handle it. About the only thing to set would be the ride height if it’s airmatic and I would leave it in the normal/comfort position.
chassis
close
- Join DateSep 2018
- Locationunbegrenzt
- Vehicle(s) I drive2017 GLE350 4MATIC
Liked:4,557 Times in 3,532 Posts
MBs eat tires. Search for it on this site. Camber and toe specified by MB is good for 130mph lane changes on the Autobahn loaded at GVW (not facetious) but doesn't work well for tire life going back and forth to Cosco.
V8s and assist systems (lane keeping, Distronic) are additionally worse for tire life.
any shop that has a decent rack can do it. hell i did my own at my buddys shop. zero'd the front and toned down the rear camber. probably have done 10k miles or so since. no abnormal wear. dont forget to rotate the wheels.
kajtek1
close
- Join DateJan 2009
- LocationV E G A S
- Vehicle(s) I drive1922 Ford Model T / no OBD
Liked:1,797 Times in 1,426 Posts
$5000 proposal is about standard I get after each stealer visit. They want to replace tires having 5mm of thread, or perform service 2000 miles before it is due.
Just get used to it.
Talking about alignments, I was getting 50,000 miles out of Firehawks on MB sedans. W212 come on low profile sport tires, so no economical rubber is available for the size, but I drive less lately so that is OK with me as the tires might age before I wear them.
To my knowledge stealers are the only fully qualified to do alignments on those cars. Some other places have Hunter machines, but what is their experience with brand?
That said, on my last alignment at dealer they released the car to me at the end of the day, when SA was no longer there and after making a scene with cashier, they found me inspection chart - showing 12 parameters in red.
I made another appointment following day and they work it again coming with only 6 parameters in red and giving me a story about corroded adjusting bolts. That was BS as the car had no corrosion.
To top it, the steering wheel was out of center. I got enough of wasting my time with stealer and having gigantic slide caliper I could buy years ago, I adjusted the steering wheel on my driveway.
S-Prihadi
close
- Join DateMay 2018
- LocationJakarta-Indonesia
- Vehicle(s) I drive2014 - W212.065 - E400 ( M276.820, 3 liter Turbo) RWD not Hybrid
Liked:6,507 Times in 3,926 Posts
To have such wear on the inside edges of the BOTH front wheel to that extend, something is wrong.
At the minimum you may need camber correction bolts, assuming all other steering + suspension components are healthy which I doubt if they have not been refreshed based on 62,000 miles work life.
If that wear is on the outside edge, it is normal, if you track the car with OEM alignment spec.
Go to a decent alignment shop with the Hunter 4 wheel alignment machine and carry your own alignment spec sheet for your car.
Sometimes the database inside those alignment machine is general and your model may differ.
You need WIS/EPC assistance based on your VIN to make sure the alignment spec is correct.
Dealer if proper and authorized should have the Romes inclinometer which can tell a lot what goes wrong even before using the alignment machine and more so if for air suspension.
You can ignore the Romes device for now if you can find that Hunter 4 wheel alignment machine + proper spec for your car.
Good luck.
Good luck.
I've found a good middle ground between the dealer and Firestone is a shop that specializes in alignments for sports cars. This is the one I use near me. They do alignments all day long for things like Ferraris, Porches, Lamborghinis, etc. and their rate isn't terrible. The nice thing is they'll talk to you about how you use/drive the car and tune it accordingly.
https://trulineseattle.com/index.html
