Sponsored by: CARiD
E400 Help with wheels & Grille
Old Jun 26, 2021 | 11:08 PM
sqitis's Avatar
C63 P31
Ok so I may be picking up this local gem 2016 E400 and I'm a previous C63 and E350 guy and wanted to know some info if I may.
1. Which size wheels 19" or 20" can I put on this car without lowering and no wheel gap? I was thinking 20" E63 wheels but may not look right without lowering and I have no clue how or what to lower this car with? Any help would be great!
2. Thinking I might replace the grille with more E63 look with the single cross bar rather than the 2 cross bar look. The car does have distronic plus for cruise so not sure what I can replace grille with.
Thoughts?
Old Jun 28, 2021 | 12:41 AM
Left Coast Geek's Avatar
2016 E350 4Matic wagon, 2019 Ford Expedition, 2019 Chevy Bolt EV
why do you want to run /25 or /30 series tires on a luxury street car? your ride will be like roller skates on a rough road.
Old Jun 28, 2021 | 08:41 AM
sqitis's Avatar
C63 P31
Just looking to fill the fender gap and have just a pinch of a more sporty ride and look. Just looking for an OEM+ setup with 19" or 20" OEM wheels.
Old Jun 28, 2021 | 10:48 AM
wait, bigger rims, you have to run lower profile tires, so the tire outer diameter should remain the same, like a 17" uses 245/45r17, a 18" is 245/40r18, 19" is 255/35r19, these are all about the same outer diameter. if you change the tire's outer diameter more than a tiny amount you mess with the suspension geometry, the car will drive awful unless you reengineer your suspension to suit.
Also, if you 'fill the gap' on the front end, the wheels won't turn without scraping and cutting rubber unless you make the suspension super stiff so there's no road compliance.
Old Jun 28, 2021 | 11:27 AM
sqitis's Avatar
C63 P31
Something like this ride height but with OEM MB wheels. Nothing too crazy but yes maybe a little lower to offset the wheel/tire size.
Old Jun 28, 2021 | 12:00 PM
have fun on driveway curbs and speedbumps.
