Sponsored by: CARiD
Lower MPG
Old Jul 18, 2021 | 05:12 PM
1965 Beto's Avatar
None
Lower MPG
Ever since the "emission update", my MPG has dropped considerably specially with AC on this hot days in NJ. Need more tuning from dealer or leave it like this?
TIA
Old Jul 19, 2021 | 04:41 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
Numbers?
We can't play with Placebo effect and yes, AC lowers mpg, although not by huge number.
Old Jul 19, 2021 | 05:27 PM
Arrie's Avatar
Originally Posted by kajtek1
Numbers?
In my car MPG reading goes down 10-15% with A/C compressor ON at highway speed. It is quite significant.
The OP may just see the MPG reduce more now when it has been quite hot around the country. It could be the compressor runs much stronger and longer now compared to "normal" summer temperatures.
In my area A/C runs compressor 100% for 8-9 months of the year so it is easy for me to see how much it helps MPG when I turn A/C OFF.
Old Jul 19, 2021 | 05:54 PM
kajtek1's Avatar
You can click on the banner in my signature, to see my records. When we don't have a month when we would not use AC at all - November and December are the months when we use it less.
Yet my mpg for those months is lower than in summer.
Biggest difference with mpg comes between driving around Las Vegas, what I consider mostly city, although we drive lot of freeway, when every few months we drive to San Francisco and then mpg goes up about 20%, regardless the fact that 80+ mph we use is not economical speed.
Old Jul 20, 2021 | 06:09 PM
Arrie's Avatar
At winter time (colder weather) MPG is typically lower.
Just turn the A/C off while cruising at highway speed and look at the MPG value how it goes higher. You should be able to drive about 5 minutes and still get cold from the vents.
Old Jul 21, 2021 | 06:12 PM
MBNUT1's Avatar
2010 E350 4Matic
Big impact of running the AC on my mileage. My wife gets mad at me when I try to run without it.
