Sponsored by: CARiD
Engine cleaning
Old Jul 24, 2021 | 03:31 AM
S. Madman's Avatar
2012 E550 sedan 2019 E63 Wagon
Engine cleaning
I have had my engine cleaned by the Mercedes dealer for the time I had it, but I want to start doing it on my own.
I have looked at this video, and it shows that Mercedes only trust Sonax 607. They even apply without any fear.
Anyone used it?
Old Jul 24, 2021 | 03:39 AM
BenzV12's Avatar
W212 FL
I wouldn't do it at all . It's not a 1956 Land Rover Defender
Old Jul 24, 2021 | 04:13 AM
S-Prihadi's Avatar
Holy cow, high power water spray that way for cars like ours with tons of electronics sensors = NO NO NO.... please no.
Old Jul 24, 2021 | 05:43 AM
S. Madman's Avatar
I would not do it this way, but it's funny how MB just goes for it.
Old Jul 24, 2021 | 07:35 AM
RA72825's Avatar
Yowza. That’s an interesting video. “Do not spray Sonax mixture on hot components”
yeah, right….
Old Jul 24, 2021 | 07:47 AM
Dane500's Avatar
2013 E550 Sedan, 2005 E500 4matic Wagon
Well I use a 50/50 of simple green to water with a soaked rag. Wipe everything down then dry off. Pull all the plastic and break out the wet/dry vac. Maybe once every two months. I don't drive around with the hood open so I don't care too much.
Old Jul 24, 2021 | 10:31 AM
bmwpowere36m3's Avatar
'11 E350, '11 E550, '98 M3, '95 E320
I do it like the video and never have issues… keep in mind technique (distance to objects) would vary if using a 1500 vs 4000 psi pressure washer. There’s more, the orifice size and angle of the tip will vary the pressure.
Point of reference, I use a 3000 psi 2.5 GPM PW, but with the right tip (down to 1200 psi) I can comfortably hold my hand less than 12” from the tip.
I’d say as long as you use a 25 or 40* tip and keep it ~6” away from components you should fine. I would avoid blasting the felt heat shield/sound lining on the firewall.
We used to have a steam “jenny”…. that was awesome for cleaning REAL grime and you didn’t need chemicals, usually. The pressure was low, <1000 psi, but it put out scalding hot water/steam.
Old Jul 24, 2021 | 12:57 PM
cvx5832's Avatar
325Ci, 325Cic, C300
I wash all my engines. Been doing this forever, and as long as it's on the up and up with no frayed wires and exposed leads you'll be good. That said I only use a foamer like this, sprayed from about 4-6 feet away and let the soap do the cleaning. Use a good soap. Then rinse using the same nozzle without the foamer attachment. Then just dry with a hand towel.
Amazon Amazon
I don't "seal" anything when I do this. Remember the engine bay is designed to be exposed to the elements, no different than driving when it's pouring out. Just skip the pressure washer and no shine products post-washing.
On our 160k-mile M272 I couldn't resist cleaning it when I did the oil plug fix. +10HP when clean, true story.
And don't forget the bike
