Sponsored by: CARiD
What happens if the drivers side of the gas tank is empty?
Old Jul 29, 2021 | 07:33 PM
Crunch69's Avatar
ML350, E550 Coupe, 53 F100, 458 Italia, 458 Spyder
what would happen if the drivers side of the gas tank is empty and the passenger side is full.? I have opened my tank when it was at a 1/4 full and there was no gas on the drivers side which would make me think the jet pump is sucking air? Would there be a DTC?
Old Aug 3, 2021 | 05:19 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
jet pumping air
I think the jet pump complication is used to bring gas from one side to the other using only the LPP gas flow. It pumping air means it's emptied the driver-side tank... I'd say that is normal.
Old Aug 3, 2021 | 08:00 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
MB keep changing the setups, but from my recollection electric pump on W212 is on passenger side, when Venturi pump is on driver side.
Venturi is using returning fuel to transfer fuel from "dead saddle" to the 1 where electric pump will push it into engine.
So with low fuel, you will have passenger side high, when driver side low, or empty.
Would Venturi fail, it would be opposite and the car would die out of fuel starvation having about 5 gallons in other saddle.
That was happening to my friend W211 when mechanic misaligned the pumps.
