Rotor/Pad Suggestions
Back in 1980's some batteries were offered with lifetime guarantee.
In those years not too many cars would last over 100k miles, not too many people kept the cars for years, so it was good advertisement to promote more sales.
My friend at the time had classic car, who he kept for years. He was on his 5th replacement, when the battery got stolen.
/me fades out singing "Time keeps on slippin' slippin' slippin... into the future..."
What is the thinking regarding rotor replacement?
a) Just replace them
b) Inspect and measure them and replace if below limit.
c) Other
large flat rate box is 12x12x5.5" inside. I doubt two rotors stacked would fit. I also doubt the box would survive intact.
For pads - Akebono are highly recommended.
Not only low dust with good braking power, but I had them for 180,000 miles and wear about 40%, so they would make 400,000 miles pads for me.
That's enough life.
my mom drives 5 mph below the speed limit and I’ve never seen her break hard enough to wear out the brakes, and she can’t even make her brakes last 150,000+ miles. Unless your math is way off (which it is because you can’t even tell what tire depth is), your 40% sounds like it’s actually 70%. Which wouldn’t make them last 200,000 miles. Relax with the constant lying.
Once they “warp” again, send them back and get new ones. You can do this as many times as you want. It’s amazing.
id stay away from ceramic pads if you live in the cold. Doesn’t brake as well as the OEM non ceramic pads. Good luck!
The only fix is going to a ceramic, Brembo NAO, Akebono EURO, Powerstop Z23, DFC 5000 Euro (I install a lot of these). Many E550's were doing annual brake services at the dealer, having completely cooked brakes at 10k. We can stretch the interval to 20-30k with ceramic pads, but the lack of initial bite and the potential of the "emergency SAFE braking system" not being calibrated for ceramic pad pedal effort is there. I haven't had any complaints with the ceramic from normal or spirited driver customers. There was this strange scenario where I put a fresh set of Pagid discs with Brembo Semi-metallic pads that warped in a month and I had Pagid honor their warranty quite easily. I have had my life saved on multiple occasions by Pagid/Textar/TRW so the idea that their parts were out of spec are out of the question, I will defend Zimmerman the same way. I've seen them go 50k on a set of discs pretty routinely and stay straight albeit worn, but on this particular car with the OEM semi metallic pads they might as well be paper plates.
and any car driven that hard will require a lot more than brakes much more often than normal.
https://mbworld.org/forums/e-class-w...vibration.html
https://mbworld.org/forums/e-class-w...e-warpage.html
https://mbworld.org/forums/e-class-w...bration-4.html
https://mbworld.org/forums/e-class-w...2011-e550.html
I've used FCP for about 10 years now and have used their lifetime warranty many, many times and never had an issue. Their customer service is top notch. That said, there still many parts I've bought from them that I never needed to exchange. The big catch is of course that you do have to mail the parts back so I don't mail things like oil, but for some expensive gear oil, maybe. I saved my rotors last time and went to mail them, but found out the shipping was going to be too steep to bother with. FWIW, I put the rotors back in their boxes, punched holes in the boxes where the lug holes are, then zip-tied the rotors together using those holes. They were pretty hefty zip ties and after doing adding five of them, it was extremely solid. I was confident the boxes would fare fine because the rotors were knocking around loose in them any more.
Even for things I don't plan on returning like rotors, I still use FCP for most purchases. They have great brands and the prices aren't typically too bad. I don't mind giving them the extra business because I appreciate the lifetime warranty and how they've treated me over the years.
Most people will blame ATE/Textar/Pagid for using Chinese manufacturing but they still pass ECE-90 and they're also installed on cars that stop from like 180mph all day. I also have personally used Pagid for close to 10 years now and I don't care where they are made they've been as dependable as Textar/Brembo/ATE for Audi/BMW/Porsche/MB across dozens of cars.
I install the same GEOMET coated rotors from nearly every manufacturer with the same results, I'm not sure why big MB sedans are weird. ATE/Pagid/Powerstop high carbon GEOMET are shown here and the castings and runout are all exactly the same across makes. The manufacturer decides the vane and hole pattern. The only variables were pad material selection and even then I can't really tell the difference between Akebono/DFC/Brembo/ACDelco ceramic. I just get whatever is available with the best margin depending application.
I mean you tell me an E63 wears discs annually and I believe it, but they don't..
