Sponsored by: CARiD
Engine oil?
Old Aug 23, 2021 | 03:41 PM
donny79's Avatar
e350
Engine oil?
I’m doing my first oil change and can I use Castrol or should I use the pento high performance? Does it really matter
Old Aug 23, 2021 | 04:00 PM
teksurv's Avatar
2024 EQE 500
Look in your manual for what the MB spec is for your engine. Many use Mobil 1.
Old Aug 23, 2021 | 04:30 PM
donny79's Avatar
e350
Ok thank you
Old Aug 23, 2021 | 04:38 PM
Left Coast Geek's Avatar
2016 E350 4Matic wagon, 2019 Ford Expedition, 2019 Chevy Bolt EV
note that regular mobil 1 that you find at BigBoxInc probably is NOT the Mercedes approved oil. An M276.9xx like is in our E350's, Mercedes specification 229.5, which is a fully synthetic 5W40, is the right oil for all but extreme cold conditions. I believe Mobile Super or Formula 1 10W40 meets this spec, so does some Castrol EDGE. I let my mechanic do my first oil change since buying the car, and they used Mercedes 229.5, so I don't have to sweat it.
Old Aug 23, 2021 | 05:02 PM
bmwpowere36m3's Avatar
'11 E350, '11 E550, '98 M3, '95 E320
0W-40 M1 from Walmart, 229.5 approved... as long as it meets 229.5 your good. Could be 0W-30, 0W-40, 5W-30, 5W-40, etc...
Old Aug 23, 2021 | 05:18 PM
cetialpha5's Avatar
Use any oil on the MB approved listed. There is NO 10w40 oil that is on the approved list. Mobil 1 0w40 is popular. Even has a rebate. Castrol 0w40 is also popular. If you feel the need to get special magic oil, you can get Mobil 1 Formula M 5w40 at the Mercedes dealer. But you'd be overpaying. Mobil is the recommended oil by Mercedes which is why there's a Mobil sticker under the hood of the car.
https://bevo.mercedes-benz.com/bevolisten/229.5_en.html
Old Aug 23, 2021 | 08:30 PM
Blkvip's Avatar
12' E559
Motul here. my car stop consuming oil after switching form whatever the dealer used before.
Old Aug 23, 2021 | 10:16 PM
Bhopkins's Avatar
2014 E350 Sport 4Matic Sedan
The key here is to get an oil that is MB Approved. Do not fall for some motor oil labeling that may state something similar to "Meets MB 229.5".
The bevo app is a great tool. It will list all the motor oils that are MB Approved. You do need to know what fluid specification your Owner's Manual refers to.
It is easy to find both Castrol and Mobil 1 in MB Approved varieties in most common auto stores.
Old Aug 24, 2021 | 12:42 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Motul pic?
It'a a really good point to tie the engine burning his own oil with the oil type in use.
These engines like a thicker xW40 more than a thinner xW30 that ends up pudling all over the intake track on the way to plugging your cats with carbon.
Old Aug 24, 2021 | 12:56 AM
oops, I'll edit my post, I meant 5W40, was my older benz that uses 10W40 or 15W40.
anyways, yeah, thats the 229.5 approved oil list, although many of those are european market oils not readily found here.
https://bevo.mercedes-benz.com/bevolisten/223.2_en.html says which specs for what engines. what I'm having a little trouble locating is the oil weight for recommended temperature range chart for a M276.9xx ... I'll be sticking with 5W40 as thats what the standard mercedes 229.5 oil is (the special AMG version is 0w40).
Old Aug 24, 2021 | 06:04 PM
Raj1471's Avatar
2011 Mercedes E350 4Matic Wagon
Mobil 1 0W-40 European Car Formula from Walmart. 5 quart jug for $23 for full synthetic engine oil which meets MB specs.
Old Aug 24, 2021 | 06:09 PM
cetialpha5's Avatar
Originally Posted by Raj1471
Mobil 1 0W-40 European Car Formula from Walmart. 5 quart jug for $22.37 for full synthetic engine oil which meets MB specs.
Don't forget the $10 Mobil 1 rebate so $12.37 for 5 quarts. Good til the end of September and Walmart does qualify for the rebate even though they may not be listed. Limit 2.
https://slickdeals.net/f/14932889-5-...mart-com-max-2
https://www.walmart.com/ip/Mobil-1-F...Quart/23636902
Old Aug 24, 2021 | 06:19 PM
MB has lots and lots of specs.... does it say "MB-APPROVAL 229.5" exactly ? Note, 229.3 is an older spec for older engines. and many oils will say "Meets MB 229.5" which doesn't actually mean much, It has not been tested and approved...
btw, I found hte viscosity chart.
https://bevo.mercedes-benz.com/bevolisten/224.1_en.html
or M276/M278 (all USA non-AMG 212's other than the early ones), ignore the weights that aren't on the 229.5 spec sheet.
Old Aug 24, 2021 | 08:17 PM
donny79's Avatar
e350
Ok great, thanks everyone I appreciate it
Old Aug 25, 2021 | 06:48 PM
Bhopkins's Avatar
The label on M1 0W-40 European Car Formula FS reads:
"Mobil 1 0W-40 European Car Formula is approved against the following manufacturer specifications:", and amongst those listed is:
"Mercedes-Benz MB-Approved 229.3, MB-Approved 229.5"
I'm not sure how Castrol or the others word it, as I don't have a bottle on hand of these. But I suspect it is similar.
Old Aug 26, 2021 | 07:40 AM
Fliplegend's Avatar
S212 E350 Estate
+ 1 on Mobil 1 Euro Formula. Been using it on my BMW's and MB's for years. Can't really go wrong especially with the rebates. I also do 7500-8K OCI's.
