Question on Intake Camshaft Adjuster with Camshaft Bolt
I have a 2013 MB 350 4Matic Sedan and recently took the car in for a Check Engine light. in further inspection, I had a Fault Code PO34600 and was told that the Driver Side Intake Camshaft Adjuster with Camshaft Bolt, Part# A 276 050 02 78 with Sealant for Cam Cover needed to be replaced - total cost was near $2,800. At first glance, this appeared excessive. Have others had similar problems and if so, was this price in the ballpark?
Also, I'm assuming that the bulk of this charge is labor, and this is just one small part that works together with other parts of the Camshaft. Are there other parts that should be replaced at the same time?
Received 1,576 Likes
2008 E350 (W211 @170K), 2012 ML350 (W166 @119K), 2014 E350 Sport (W212 @96K), 2015 ML350 (W166 @92K)
Nope, that sounds about right. Labor intensive and the entire phase actuator must be replaced, and they alone are like $600 bux. Bank 1 seems to be most commonly affected, but either are of course, susceptible. You should consider replacing both bank intake phasers while you're in there if you're going to keep the car. Here is a good example and explanation of your issue:
