What that noise?
These blowers tend to fail (squeak), but the ones I have seen/heard the noise is more like missing lubrication, i.e. metal to metal squeaking.
Here would be my initial approach:
Open the hood
Remove the cover into the AC inlet, see picture below
Once removed, you should see your main battery and the entry/inlet to the AC. You should be able to see the plastic blower wheel from there
Update: Before the next step, check if there is something that should not be there, perhaps a flashlight would help as well.
Turn the key to position 2, keep the engine OFF, and turn the AC on, you should hear the blower. Go back to the underhood and look at the blower area. Check for the noise or something that should not be there.
Just be careful with the plastic blower wheel. Do not remove any fixed piece attached to it (balance weights for example), nor try to force it into any position. If you unbalance the wheel position, the noise will be worse
since it can now rub the blower shroud.Update:, CAREFUL with the spinning blower, you do not want your hands in there
To replace the filter (only possible from the cabin) here is a video showing the steps
Open the hood
since it can now rub the blower shroud.To replace the filter (only possible from the cabin) here is a video showing the steps
https://www.youtube.com/watch?v=srP4sUM9A3o
Yes this is was recorded with the engine idling, I’ll get back to you with results
