Oil transmission question
E class 220 Bluetec 2014
Hi everyone
I have E class 220 Bluetec 2014,I have all ready 55k miles,can I change the oil transmission now or when I will made 70k miles (my one has blue oil not red)
Received 3,335 Likes
MY'14 W212 M276 3.5NA @55kMi
ATF service... a good habit 👍
yes, 1st service as soon as possible around 50kMi and as often as you care to or 35kMi based on driving city vs. Hwy.
The blue ATF is really low viscosity and likely not the best at holding pressure in worn clutch packs. From low clutch pressure comes additional slippage, overheating and more sludge: a vicious cycle of destruction.
The clutch friction/steel material stays inside the transmission and keep circulating around.
The larger chunks get stopped by coarse filter and solenoid strainers.
Ferrous particles are grabbed by the pan magnet.
Earlier better than late!
Changing the oil is piece of mind , I think I would change it as well . Honestly, I have not heard of blue ATF .
2020 E 300 Coupe and 2019 GLS 400
It is NOT to be used in older 722.9 transmissions, and SHOULD NOT be mixed with the older red 236.14 fluid.
The following 4 users liked this post by Solo wing:
Received 1,488 Likes
The blue ATF is basically ATF 134 FE, the older red fluid was just ATF 134. They're both available at a shell distributor or you maybe you can get your local shell station to order it for you. I got a case of ATF 134 directly from the shell distributor for my W211, it was around $60 for the case, the ATF 134 FE was just slightly more for a case of 12 quarts. Much cheaper than the dealer which is typically over $20 a quart.
The following 3 users liked this post by cetialpha5:
